Question about Tonino Lamborghini 5014.61 Gents Pilot Black Dial Watch ()
Set gmt time on tonino lamborghini pilot watch
Which button do i press and hold on the side of the dial?
Set reserve indicator on invicta 6106
Here is how to set the Invicta 6106 Invicta 6107 and other similar models with the ISASWISS 8173 movement with the following functions:
TIME - DATE - DAY - ALARM - GMT - POWER RESERVE
DO THINGS IN THIS ORDER AND YOU WILL FIND IT TO BE VERY EASY! After you understand how to set ALL the functions you can skip steps later to set individual functions but for now just do it exactly step by step:
1. Unscrew the center crown (if it is a screw down crown) and pull it all the way out (this is position 2) and turn it until you see the DAY sub-dial at the 6:00 position set to the day BEFORE today. There is no QUICK SET for the day on this movement so you must just keep turning the crown and hour hand past 12 midnight and watch the day pointer until it gets to the day you want - the day BEFORE today.
2. Now set the time to 6:00 (am or pm doesn't matter at this point). This is very important because you do not want the time to be between 9:00pm and 12:00pm when you set the date later on - we are using 6:00 just to be safe.
3. Push the crown all the way in - you don't have to screw it down.
4. Now pull out the crown very gently to the 1st position - just one "click" out. Now turn the crown AWAY from you to set the date to the date BEFORE today - this appears in the small window at the 4:00 position.
5. Now pull the crown all the way out again to position 2 and turn it away from you until it goes past 12 midnight and TODAY's DAY AND DATE are showing and then adjust the hour and minute hands to the current time - be sure to set the hour to AM or PM and push the crown all the way in. If you wish to set the seconds exactly - with the crown pushed in watch until the small seconds hand in the sub-dial at 2:00 is exactly at 60 and then pull the crown out to Position 2. Set the time ahead a minute or so and push the crown in when the actual time is the time you have set - you can set it to atomic clock time on the internet or by another watch that sets itself to atomic time.
6. Now the DAY, DATE and TIME are set to current. Now when the hour hand passes 12 at midnight tonight the DAY and DATE will advance correctly.
YOU CAN STOP HERE IF YOU WISH - but you can continue on to set the ALARM and the GMT indicators as follows:
7. To set the GMT hand (the one with the red-bordered pointer) the crown is pushed all the way in and screwed down. Now simply hold the bottom pusher in for a few seconds until you hear a beep - now you can start pushing it and watch the GMT hand moving - one push at a time for small adjustment or hold it down to make it move faster. When you stop pushing it another beep indicates that it is OUT of the setting mode - so if you want to adjust it again just hold it in until short beep and start pushing the lower pusher same as above.
Understanding GMT (or second time zone): Note that the GMT hand time is indicated on the 24 hour dial (think in military time where 3:00AM is 0300 and 3:00PM is 1500) using the very small numbers around the very outside of the dial. When the local time is 3:00PM if GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "15" which is between the 7:00 and 8:00 hour markers. If the local time is 3:00AM and the GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "3" between the 1:00 and 2:00 hour markers. So lets say you are in Pacific Time Zone and it is now 3:00pm local time and showing on the minute and hour hands - and for example you want the GMT hand to show Eastern (New York) time which is 6:00pm (in military time that is 1800 indicated by the very small 18 which aligns with 9:00) - hold in the bottom pusher until you hear a beep - now start pushing it in short increments or hold it down to move it faster until it points to small 18 (large 9). Now the GMT will indicate the hour in the EASTERN time zone while the main hour hand indicates your local time.
7. To set the ALARM - unscrew the crown and pull it to Position 1. Turn it TOWARDS you (if you turn it way from you will set the date which you don't want to do) and you will see the hand with the white pointer and the word "Alarm" in tiny writing on it move clockwise. Set the ALARM to the time you want. Push in the crown and screw it down.
8. To activate the ALARM push the TOP PUSHER once - the small hand in the POWER RESERVE sub-dial will move slightly and then it will move again (give it a second or so) and you will hear a BEEP - now the alarm is activated and the small hand points to the "ON" label. When the alarm sounds if you wish to stop it push the top pusher. But it will stop on its own and then repeat a few minutes later - you can just leave it alone if you wish. Note that the Alarm will turn OFF after sounding - so if you want to wake up for work on time tomorrow be sure the ALARM indicator is pointing to "ON".
9. To deactivate the ALARM when the small hand is pointing towards the "ON" label simply push the top pusher again and and the small hand will move clockwise down to the "OFF" label.
10. POWER RESERVE sub-dial. To align the Power Reserve sub-dial hand (after battery change) pull the crown out to Position 1 and push the top pusher until the hand points to 0%. Push the crown back in and screw it down.
11. Reserve Indicator - the instructions for this movement states that holding down the top pusher for 3 seconds will move the POWER RESERVE hand to the power reserve scale - but this is confusing because the hand never actually stays on the power reserve scale - it will only stay on "ON" or on "OFF".
However - I believe that this is the way it works. When you push the top pusher with the small hand in the "OFF" position it will momentarily move to the power reserve scale and stop for a second before it moves again to "ON" - I believe that this reading indicates the POWER RESERVE just before it moves again to the "ON" position..
Jan 03, 2012 | Invicta Reserve Watches
Tip
HOW DO I SET MY DIGITAL -- (PUSH BUTTON) -- WATCH
mcdevito75 here, The Quartz Mechanism is made in such a way, that the battery"s electricity changes in a way, while going thru the Quartz and thus Display"s the Numbers and or Letters on the Dial or Display, By PRESSING these Various Buttons, you are Changeing the Battery"s Voltage thru the Quartz and thus Displaying the Numbers and or Letters. ---------- Genarally, you need worry about only TWO (2) of these Buttons to SET your DIGITAL (push button) Watch, They are the MODE and SET Buttons. ------------- The MODE Button is usually on the Right side of the caseing, PRESS this Button, depending on your watch you may have to hold down this MODE Button 2--3 seconds, once you see the Dial Or Display BLINKING you are set to RE--SET your watch, NOW, PRESS the SET Button, usually on the LEFT side of the caseing to change each Function (Hour, Minute Etc.) once each Function is SET, PRESS the MODE Button to move onto the next Function. ------ Once all the Functions are SET, PRESS MODE again to see a STEADY Display or Dial. ---- It May take a little practice so be patient. ------ Some DIGITAL watches may not have a MODE BUTTON, But Rather a DIMPLE on the watch caseing you would PUSH in with a PIN or Tooth Pick, same MODE and SET procedures would apply. --------- Use your watches name plus .com online to obtain a user manual or look for a small watch repair shop in your area to order a NEW owners manual for your watch.
on Jul 10, 2010 | Watches
Howdo I set time on a puma watch pu910222003 blockbuster circuit touch screen
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 20, 2011 | Watches
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
I have a tonino lamborghini watch and cant figure out how to set the time
The stainless steel band broke on my Tonino Lamborghini watch. Can anyone tell me how and where to get a new band? Or even a replacement link for mine?
Jan 07, 2011 | Bulova Watch
I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
Dont have that particular watch, but try this.
Day to day use,
Cool feature,
Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    Manual Receive of Atomic Clock time on Casio Watch not working
    I have the same problem.  Following the instructions, by pressing A it wants to set the GMT differential. It will not go into manual receive mode.
    Jun 05, 2009 | Casio Watches
    I have a ceptor 4305 module, i live in UK, DST time is 2pm but my watch is showing 4pm. How can I adjust to the correct time?
    hold down the bottom right button for 5 seconds, until second hand goes to 12 and stays there.
    keep pressing top right button through sequence of numbers and letters until it reaches 0, ie time difference to GMT. press bottom right button 10 times to restart watch
    Apr 14, 2009 | Casio Waveceptor Atomic VQ200HA 1AV watch
    WATCH
    Press MODE 5 times until you see H-SET on the right side of the dial in the box. Then press the ADJUST button. You will now notice the current TIME you have already set on your watch will appear in the box and flash where H-SET was. This will help you know what time to set the hands on. While holding down the FORWARD button you will see the hand start to move. I could not move mine in reverse, only forward. Simply set the time and you are finished.
    Jul 18, 2008 | Casio G-Shock G511-1AV Wrist Watch
    Tonino Lamborghini 5014.61 Gents Pilot Black Dial Watch () Logo
    64 people viewed this question
    Top Tonino Lamborghini Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Tonino Lamborghini Watch Expert? Answer questions, earn points and help others
