Question about IBM ThinkPad R52 Notebook
R52 operating system not found
BROAD UNID PXE -2.1 V7.7.5 COPYRIGT [C] 2000-2004 BROADCOM CORPORATION COPYRIGHT [C] 1997-2000 INTEL CORPORATION ALL RIGHT RESERVED BROADCOM BASE CODE PXE 2.1 V1.0.1 COPYRIGT [C] 2000-2004 BROADCOM CORPORATION COPYRIGHT [C] 1997-2000 INTEL CORPORATION PXE-E61: MEDIA TEST FAILURE, CHECK CABLE PXE -M0F: EXITING BROADCOM PXE ROM. OPERATING SYSTEM NOT FOUND
  • IBM Master
  • 3,320 Answers
You have set up the computer BIOS to boot from the network card. That means the BIOS starts up the network card which goes out on a company LAN to look for the operating system
If you did this by mistake while playing in the BIOS then you can go into the BIOS , usually by pressing F2 when you first turn the computer on, and going to boot menu and picking your hard drive.
If you bought the laptop the way it is, then it probably doesn't have an OS on the hard drive and may not have a hard drive at all.
If you came by this laptop by illegal means then I am chuckling at your misfortune.
Posted on Mar 23, 2014
2 Suggested Answers
Davethesnake
  • 689 Answers
SOURCE: it appears INTEL(R)BOOT AGENT CE
re-load OS from cd/dvd,dont play with the keys unessesarily whilst you are re-installing
Posted on Oct 20, 2010
Hello, I have very old IBM ThinkPad laptop that I never use anymore. Now I remembered that I have some files on it I have to get (also websites that I had put on favorites). When I try to turn on the...
Hi.
I think the boot order on the laptop has been changed and the laptop is trying to boot from the LAN (NIC/Ethernet) port.
To change the boot order you need to access the BIOS. On older IBM laptops (and this is dependant on the model) the BIOS Utility is entered by holding F2 while the ThinkPad logo is displayed after power on, or, with the unit powered off, hold the F1 key and power the unit on. Keep F1 held down until Easy setup appear. The key is either F1 or F2.
On other models there is a blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
once in the BIOS look for the boot order of the computer and change the boot order to the HDD (hard disk drive). There will be instructions on the screen on how to change the boot order. Save the changes and restart the laptop. Hopefully it will now boot into the hard drive and load the operating system.
Hope this helps!!!
Regards.
May 23, 2011 | Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Hi, When I turn on my Laptop - Acer Aspire 5536, the following writing appears; Broadcom UNDI PXE-2.1 v11 .4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel...
usually, this message means that when your computer is booting it is trying get the operating system files from a network location (shared folder)
what you need to do is to make sure your BIOS is not set to boot from network.
1. when the computer starts, there is a message like "to enter BIOS press Esc" or any other key like F2 or F10
2. in the BIOs settings, make sure the order of the boot is: DVD/CD then hard disk. make sure there is no Network booting in the list
Oct 26, 2010 | Acer Aspire 3690-2196 Notebook
I was using my laptop last night when it just shut down on me, then when i went to turn it back on it goes to the acer "start up" like page before skipping to a black screen and displaying the following...
If you have a BOOT CD then try to boot and go to windows.
Or you can use windows setup CD but go for repair only.
For the future it is a good idea to INSTALL WINDOWS in a USB mini drive and boot the computer from USB. You have to go to BIOS and set USB default drive.
It is a good idea to clone your HD in a CD.
Sep 04, 2010 | Acer Aspire 3690-2196 Notebook
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
Jun 24, 2010 | Computers & Internet
Broadcom UNDI PXE 2.1 v11 . 4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE- 2.1 v1.1.0 Copyright (C)...
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Jun 16, 2010 | Acer Aspire 3690-2196 Notebook
Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Mar 31, 2010 | Lenovo 3000 G530 Notebook
My computer which got on friday is not working, when i start my computer it goes to a black screen. And than this message comes up: Broadcom UNDI PXE - 2.1 v11.4.1 Copyright (C) 2000-2008 Broadcom...
What is your computer brand?
Just turn it on and keep pressing esc or delete or F2 key (depending on the model. But yuo can try any of them. This will take you into the bios screen. In the bios check if hdd is detected. If not - replace HDD>if yes > reset bios to defaults and start recovery (using supplied RDVDs or Recovery partition.
You will find exact instructions in user manual.t
thanx
Sep 14, 2009 | Acer Aspire 3690-2196 Notebook
My acer aspire 5315 is stuck on dis screen, n I don't have a reco
Hello my friend, regarding on your problem it is clearly that your system cannot boot from its kernel part of the Operating system. It is experiencing a software corruption or corrupted files of your operating system. The only solution you can get is to re install your operating system to replace and repair any damage files in your operating system.
Thanks
Jul 16, 2009 | Computers & Internet
My acer aspire 5315 is stuck on dis screen, n I don't have a recovery disk to reformat it, wat can I do? Broadcom UNDI PXE-2.1 v10.0.9 Copyright (C) 2000-2006 Broadcom Corporation Copyright (C) 1997-2000...
your operating system is broken. or infected by virus, file corrupted.. neet to repair if could.. but if not re install the os...
save first all the inportand documents in external hdd or in drive d before to start re install the os
Jun 14, 2009 | Computers & Internet
IBM ThinkPad R52 Notebook Logo
67 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
