Lg wt r107
No power on machine at all .checked power point and have power there
I need an instruction manual for a LG WT-H755TH washing machine
10th item in a simple GOOGLE search for
LG WT-H755TH user manual!
You can view or download it from this website.
http://e.manualretriever.com/lect.php?ID=505713&lg=E&h=d41d8cd98f00b204e9800998ecf8427e&src=15
Jul 18, 2016 | LG Washing Machines
I replaced the drain pump but machine is making a noise like its goin through spin cycle when turned on. Water drains right out aswell HELP
if the pump is working all the time then it will be the program board
make sure that after you replaced the pump the drain hose outlet was higher than the tub or all the water will run out
Feb 23, 2016 | Washing Machines
What dose PE MEAN
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Aug 08, 2014 | LG Washing Machines
Lg fuzzy logic 8.5kg WT T857 washing machine
THERE IS THREE POINT TO CHECK.
O1 .INLET VALVE SHORT CI-CUTS
02. PRESSER SENSOR SHORT CIRCUITS
03 .PRESSER SENSOR TUBE MIGHT BLOCKAGE WITH DUSTY,
Dec 13, 2013 | Washing Machines
Manual for lg washing machine wtr854
LG has the manual for the WT-R854 on their site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-R854.jsp . Click on the Support tab and then look on the right side of the page.
I hope this helps.
Jan 12, 2012 | Washing Machines
Users manual
The LG Canada website has it.
http://ca.lgservice.com/index_b2c.jsp
Click on "Owner's Manuals" on the left hand menu and fill in the details, model number WF-T8016TP. You'll need IE, not Firefox...
Jan 24, 2009 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
