Question about Bosch Benvenuto B20 Espresso & Coffee Maker
Warning light red circle with line through it
Warning light with red circle and line comes on when I turn machine on
Toyota celica dash board red light light comes on looks like a pan with steam symbls coming outt steaming pan is it the breaks or catalatic converter heating up
There is no warning light for catalytic converter heating uo. Brake light usually is a exclamation mark inside a circle inside parentheses. What you are describing sounds more like a temperature warning light for the cooling system.
Nov 12, 2016 | Toyota Cars & Trucks
I have a red dash warning light (no manual) & warning ping when I start up engine. Symbol is like an exclamation mark in circle with outside incomplete circle-lines Cheers
this light for coolant level indicator top up coolant level then s.w off and on , check for coolant leakage may be leakage from radiator sender.
Jun 18, 2011 | Volkswagen Golf Cars & Trucks
BMW 1999 mdl 323i, yellow light on in dash. round circle with 3 lines on each side. can you please tell me how to remove this warning light. thank you joe
A ROUND YELLOW CIRCLE LIGHT WITH LINES ON EACH SIDE MEANS BRAKE PROBLEMS FRONT BRAKES OR REAR BRAKES HAS A FAULT. NOW IF CIRCLE HAS LINES INSIDE YOUR POWER STEERING FLUID LOW NEED CHECKING.THE WARNING LIGHT WILL TURN OFF WHEN PROBLEM FIX.
Jan 24, 2011 | 1999 BMW 323 Series
I have a an unidentified warning light on in my dash. If the odometer was a clock, it is located at about 7:00. IS looks like circle with an exclamation mark inside, it has a small square on top of the...
the only one i could find that looks like the one you described (trouble light) is tire pressure. sorry i couldnt be more help. although a faster turn signal flash can sometimes be a burnt out bulb on the fast flashing side.
Aug 24, 2010 | 2005 Dodge Dakota
1999 Audi A4 warning lights
look like it's your brake warning light, have some one check your brake pads, brake fluid and parking brakes
Mar 29, 2010 | 1999 Audi A4
I have a warning light on that looks like a circle on a 1990 volv
this means the brakes are low, have your brakes checked, hope this helps.
Feb 19, 2010 | 1990 Volvo 240
What does this light mean on my dashboard?
this sounds like the Traction/Stability control and ABS warning lights, they are art of the same system and come on together.
Apr 21, 2009 | Renault Sport Cars & Trucks
Warning lights on instrument panel
sounds like you are talking about the bulb out light /try turning off the lights with eng. running /does it go out
Jul 28, 2008 | 1991 Volvo 740
Bosch Benvenuto B20 Espresso & Coffee Maker Logo
21 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
