Question about Whirlpool WTW6600SW Top Load
Error code LD
Slow draining
3 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: i have a cabrio washer
Friend,
ngfam1 At your service!
When it is a code the machine is telling you that there is a fault and the electronic system needs to be diagnosed by a trained tech.
My advise is,
You spent enough money buying that Cabrio to be experimenting and guessing and buying expensive parts for it!
Let the tech fix it 123 and your done. It may not have needed the drain pump and now that money could have covered the service call!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 30, 2008
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
We got error code SL or it may have been 5L...not sure but it was after the Ld code..what does that mean?
this is a long or slow drain issue you will need to check the drain pump for obstructions.
Feb 02, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Our washer beeps, stops, and says LD.
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite keeps flashing LD after I start to wash. Then the machine stops washing. Clothes are not wet, but I heard water going into the machine. How can i fix this?
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Jul 27, 2009 | Kenmore Washing Machines
My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Jul 09, 2009 | Maytag Bravos MTW6600T Top Load Washer
Kenmore Elite Oasis HE top loader has LD error code
Jun 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Ld code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question !!!!
Jun 02, 2009 | Kenmore Oasis 27042 Top Load Washer
What does it mean when LD shows in the display on my washer?
Apr 03, 2009 | Kenmore Elite 20972
Error code "LD" (long drain) flashes....
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Ld code on any cycle
Feb 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool WTW6600SW Top Load Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal De
