Sony lcd red blinks 6
My sony kf50we610 wont turn on everytime I try the power/standby light blinks 6 times green and than it blinks 6 times red and than another 6 times red
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Posted on Mar 23, 2014
  • 1694 Answers
SOURCE: tv blinks 6 red blinks
Thermal Fuse kit needs replacement = part # 1-910-023-93
Qualified tech only.....T.
Posted on Jun 27, 2008
SOURCE: red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Posted on Feb 09, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Posted on Feb 14, 2009
techman007
  • 1112 Answers
SOURCE: sony kdf50e2000 manufactured 11/2006
Hi:
This error code is a result of a failed Thermister, the thermal resistor acts like a fuse but detects overheating in the lamp compartment.You will need to call a servicer to replace as it will require the taking out of the optics engine assembly, or light engine. When this parts opens, it signals the microprocessor that the termister is open resulting in 6 blinks on the LED.
Posted on Nov 10, 2010
Kensolutions
  • 455 Answers
SOURCE: sony 3 lcd rear projection tv hd w/ wega gate.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jun 12, 2011
The power/standby light blinks red 6 times on my Sony KF50WE610 and there is no picture. What does this error code mean?
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Not a DIY fix
Please rate my help++++Thanks for using FIXYA
Aug 01, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
When I turn on my TV (KF50WE610), it makes ticking
Hi,it sounds like a problem with your ballast.The ballast is the board that powers the lamp .When it starting to fail it will make clicking sounds.The part is around $40-$60 depending where you look for it.I believe there's instructions on youtube.Have a bless one!
Feb 09, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
When switching the tv on onlypower/standby red light comes on not
How many blinks when its red ?
The blinking is a code from the microprocessor telling why it's not turning on.
Apr 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Red standby light light blinking
Jan 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Standby light blinks 6 times
It is fuse issue again. Go to this website and you should have solution or ask for one:
http://www.avsforum.com/avs-vb/showthread.php?t=507602
Dec 18, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Standby light flashes
the lamp thermal sensor is probably bad...you ma also have a lot of dust around the lamp fan..there is a service kit for this problem.
a1137954a..you must clean all the dust from the fan above the lamp or replace it.
Nov 28, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
198 people viewed this question
Top Televison & Video Experts
