Question about Kenmore Sewing Machines
Install a thread spool pin
Both thread spool pins are broken off. I have ordered new ones but need to know how to install them.
    Champion:
    Habit-Forming:
  • 201 Answers
  • 12 Answers
SOURCE: thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
Posted on Jan 19, 2008
SOURCE: spool pin
Spool pin is usually on the top Right hand side of the machine. It is sometimes not clearly visible (it looks like a small metal rod protuding out, but not long enough to hold your thread). You will have to pull it up so that it extended and then you can use it.
Posted on Jun 09, 2008
talk2ginny
  • 34 Answers
SOURCE: Lost Spool pin and cap for QuikStitch SP-402
Welcome to FixYa. If you have a spool stand, that might work as long as you can thread the machine properly (give it a try!). When the thread is placed on the machine's spool pin, the spool cap keeps the thread in place and helps the thread unwind evenly - so if you are using a spool pin, you really do need a spool cap.
If the spool stand works, you are good to go. If you need to order replacement parts, I've provided a link the manufacturer's website. From there, you can contact customer support and find out if parts are available. If you can't order replacement parts, ask customer service if the machine is compatible with another brand. Another option would be to buy a spool pin and cap at a sewing machine dealer. Take the machine with you and and make sure the parts fit before you buy them.
Here's the link to the site I mentioned:
http://www.topinnovations.com/products/sew/SP-402/SP-402.html
Thanks for stopping by. If you have an extra minute, feel free to rate my solution. I'm eager to improve my solutions if they are not helpful. If you have further questions or would like to consult with another FixYa expert, just leave a comment and I'll do what I can to resolve your problem.
Posted on Jan 31, 2009
  • 22 Answers
SOURCE: Jammed spool pin on a Brother CE5000 PRW sewing machine
Try a little oil and let it set befor pulling.
Posted on Nov 10, 2009
Testimonial: "Awesome solution- thanks so much!"
  • 1116 Answers
SOURCE: How do I replace a broken spool pin on the Brother
If the spool pops in, you may be able to find a replacement where sewing machine parts are sold.
If it was a molded to a platform, a thread stand may be a less expensive method to use. You can find a single cone thread stand with sewing notions.
http://www.sewingmachine221sale.bizland.com/store/page24.html/
Posted on Mar 29, 2010
How to remove broken horizontal spool pin of Singer Sewing machine model 6550 and replace with new spool pin?
It appears to be just "hooked" on according to the photo, and you can get the replacement part for $4.00 using this link: http://www.sewingpartsonline.com/spool-pin-singer-3709-sewing-machine.aspx.
However, before you go to all that trouble, you can also just use the auxiliary spool pin used for twin needle sewing which came with your machine but can be purchased from the same site for about the same price.
I don't use either -- I just put the spool in a cup behind the machine and thread from there. See? One way or another, you're back in business!
Jul 06, 2017 | Singer Sewing Machines
How to change the thread spool pin on babylock model esp
Depends. Some spool pins simply push in and snap in place, but as many machine brands existing, there are probably double the different spool pins available...
http://www.sewingpartsonline.com/babylock-esp-sewing-machine-parts.aspx If you order from one of the online vendors, they will probably be able to advise how to install it.
Spool Pin for Brother Baby Lock X59053051 Old X59053022 X59053052
SPOOL PIN Babylock ESL ESP Espire Brother CS8072 PC2800 PC3000 PC6500...
Mar 24, 2017 | Sewing Machines
I have a brother xl5012 and would like to change the spool pin..not sure if its broken? the one on top is silver and the spare is plastic..not sure what to do..the manual has no answers.. thank you
On most machines, the spool pin simply screws into a threaded hole. If it was welded on or attached in some other permanent way, changing it may need a service visit. Brother has one of the very best service departments of any company I know. But try to unscrew the old one.. it might be stuck, a drop of penetrating oil, or maybe some pliers, might assist. If it comes out, a new one should screw in easily enough, so long as it matches the size of the hole and the threading.
Nov 17, 2014 | Sewing Machines
I have a singer featherweight 11 117 model and the spool pin snapped. Where can I get a replacement?
First of all, it's likely at this point that you think your machine is unusable without it, but you're wrong. I have four Singer high-end sewing and embroidery machines, and it has been years since I used their spool pins.
Simply put a coffee cup or--my favorite--a lidless pint Mason Jar at the back of your sewing machine towards the right (away from the fabric side), bend the thread (don't wind the thread) around the remains of the spool pin to use it as a thread guide, and then thread the way you usually do, and you are in business!
Now, to address the replacement issue, there are several places where you can order a new one. Do a search on eBay for "Singer Featherweight Spool Pin" and a number of listings will come up. Don't put in your model number in the search box. If you see that a dealer is featuring one for a Featherweight, but not for your model, don't hesitate to use the "Ask a Question" option in a listing; these are generally quite knowledgeable dealers who can order one for you. Also Jenny's Sewing Studio and Sewing Parts Online either have them in stock or can order them for you. It appears that they are quite inexpensive too!
Aug 04, 2014 | Singer Featherweight II 117
Twin needle
Hello
Install the second spool pin.
Place the two spools on the spools pins, one on each spool pin.Make sure that the spools are spinning toward each other.
Thread as for single needle.
Thread each needle from a different spool.
Caution: Make sure that the stitch width is not wide than the twin needle maximum swing. Check that the needles will not hit the throat plate as they swing from left to right and back again on stitches with width.
Happy twin needling
Sewingirl/
Jan 30, 2014 | Husqvarna Huskystar 207 Sewing Machine
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
Janome Rx 18S just purchased one second hand online and 1 of the spool pins are broken off. What was the purpose of the 2nd one and where can I find a replacement?
they are only used if your sewing with double needles to hold the
other spool of thread,, most people just buy a thread holder to set
at the back of their sewing machine
here's a link for one for the machine, but a generic spool or cone
holder is just as good,
http://www.sewingmachine-sales.co.uk/twin-needle-spool-pin.htm
Oct 09, 2012 | Janome Sewing Machines
Elna lock overlock 5 thread sewing machine, the thread guide pole is broken and I need to replace
you should be able to buy this part from either a local Dealer who stocks Elna or from online. try www. sewingpartsonline.com or www.sewusa.com
Sep 18, 2011 | Sewing Machines
Broken plastic part within which thread spool pin is inserted
You can search for:
Make Model parts diagram
to see what replacement parts are available.
If not, you can probably devise something to improvise. I've used plastic drinking straws as spool pins, or plastic chop sticks.
Jun 27, 2017 | Janome Sewing Machines
Oct 25, 2008 | Sew Pro QuickStitch SP-402 Mechanical...
Sewing Machines Logo
275 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
