Cannot load O S due to missing file
SYSTEM REPORTS MISSING FILE
  • 58 Answers
You need to tell us what OS. Windows (what ver?) Linux (what ver ?)
Posted on Mar 30, 2014
Bootmgr missing or corrupt
To repair missing or corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
May 07, 2013 | Toshiba Satellite Computers & Internet
How do i download missing firmware for ubuntu
Loading Missing Firmware As described in the section called "Devices Requiring Firmware", some devices require firmware to be loaded. In most cases the device will not work at all if the firmware is not available; sometimes basic functionality is not impaired if it is missing and the firmware is only needed to enable additional features.
If a device driver requests firmware that is not available, debian-installer will display a dialog offering to load the missing firmware. If this option is selected, debian-installer will scan available devices for either loose firmware files or packages containing firmware. If found, the firmware will be copied to the correct location (/lib/firmware) and the driver module will be reloaded.
note.png Which devices are scanned and which file systems are supported depends on the architecture, the installation method and the stage of the installation. Especially during the early stages of the installation, loading the firmware is most likely to succeed from a FAT-formatted floppy disk or USB stick.
Note that it is possible to skip loading the firmware if you know the device will also function without it, or if the device is not needed during the installation.
warning.png Support for loading firmware is still relatively basic and is likely to be improved in future releases of the installer. Currently debian-installer will for example not display any warning if you choose to load missing firmware, but the requested firmware is not found. Please report any issues you encounter by filing an installation report (see the section called "Submitting Installation Reports").
Preparing a medium Although in some cases the firmware can also be loaded from a partition on a hard disk, the most common method to load firmware will be from some removable medium such as a floppy disk or a USB stick. The firmware files or packages must be placed in either the root directory or a directory named /firmware of the file system on the medium. The recommended file system to use is FAT as that is most certain to be supported during the early stages of the installation.
Tarballs containing current packages for the most common firmware are available from:
Just download the tarball for the correct release and unpack it to the file system on the medium.
If the firmware you need is not included in the tarball, you can also download specific firmware packages from the (non-free section of the) archive. The following overview should list most available firmware packages but is not guaranteed to be complete and may also contain non-firmware packages:
It is also possible to copy individual firmware files to the medium. Loose firmware could be obtained for example from an already installed system or from a hardware vendor.
Firmware and the Installed System Any firmware loaded during the installation will be copied automatically to the installed system. In most cases this will ensure that the device that requires the firmware will also work correctly after the system is rebooted into the installed system. However, if the installed system runs a different kernel version from the installer there is a slight chance that the firmware cannot be loaded due to version skew.
If the firmware was loaded from a firmware package, debian-installer will also install this package for the installed system and will automatically add the non-free section of the package archive in APT's sources.list. This has the advantage that the firmware should be updated automatically if a new version becomes available.
If loading the firmware was skipped during the installation, the relevant device will probably not work with the installed system until the firmware (package) is installed manually.
note.png If the firmware was loaded from loose firmware files, the firmware copied to the installed system will not be automatically updated unless the corresponding firmware package (if available) is installed after the installation is completed.
hope this helps
Jul 17, 2012 | Computers & Internet
I have a Designjet z2100. I loaded the drivers from the support site. Whenever I print, the printer display reports wrong file format. I am using window 7 64 bit and have tried using windows update to...
Next time include the System error code, in this case 61:XX.
Power off and remove the power cord. Reconnect and power on. Make sure that the correct driver is loaded.
Make sure that the Graphic language setting is correct.
Resend the file to the printer.
Make sure that the Firmware is up to date. Upgrading the Firmware will re-install the PostScript fonts.
It is also possible that the file is password protected.
Do all files fail?
Mar 25, 2011 | HP DesignJet Z2100 InkJet Photo Printer
Won't load program missing oleaut32.dll
You can download the dll file here:
www.dll-files.com/dllindex/dll-files.shtml?oleaut32
Mar 25, 2010 | Pinnacle Studio AV/DV version 8...
Code 39 on DVD Philips SDVD8821
Download the latest driver from Acer site or phillips site.
Uninstall the device driver.
Reboot
Windows should detect new hardware and start the wizard. Point to your drver installation file and install the driver.
Reboot. this should fix the problem.
Apr 26, 2009 | Acer TravelMate 4220AWLMi Notebook
Recovery Disk can not recover system
It could be a hard drive crash. Can you refort the hard drive and see if you get any errors.
Check to see if you have any scratched on the CD.
Jun 22, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
David Payne
David Payne
