Question about Craftsman 2700 Max Psi Pressure Washer 23 Max Gpm
Washer pulses in operation
Engine pulses when the nozzle trigger us pressed.
Motor pulses on full power wash
It sounds like you either have a clogged nozzle or one that is too small for your pump. At lower speeds the pump is pumping less gpm. So your unloader valve does not cycle. Then when you go to full power. The engine is running faster and pumping more gallons per minute. The nozzle is too small or clogged and so the bypass opens and closes ( surges) Try a new nozzle that is the right size for your machine.
Oct 09, 2014 | Karcher 2500 PSI Pressure Washer
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
When the spry trigger is pressed the engine boggs down and stops. Is there a relief valve stuck maybe.
This issue is caused by defective unloader or debris trapped in spray nozzle or faulty gun. Easy to check. Check system with-out spray nozzle. The engine should not labor at all when you depress trigger without nozzle. If it labors/ dies faulty gun, if no labor, install new or clean nozzle (check for correct gpm for machine) and retest. If ok, you are done, if engine labors or dies, reduce pressure by turning pressure knob as required. If reducing pressure has no effect, most likely faulty unloader. Good luck
Oct 06, 2010 | Coleman Pressure Washer PW0881800
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
Karcher 2400 psi blaster When you release the trigger it will not pick up pressure when you use it again
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace a $5 (maybe) part, and it took about 5 minutes.
Sep 12, 2008 | Karcher 2500 PSI Pressure Washer
There is no pressure
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace about a $5 (maybe) part, and it took about 5 minutes.
Sep 11, 2008 | Karcher 2500 PSI Pressure Washer
Craftsman 2700 Max Psi Pressure Washer 23 Max Gpm Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
