Question about LG WM-1832C Front Load Washer
Delay Wash Delay Time will not go past nine hours,it then shows wash cycle time
  • 105 Answers
Must be only 9 hour timer in this model
Posted on Jan 28, 2008
What is "delay wash" & how is it operated?
If you're washing machine is equipped with Delay wash.The delay start feature allows you to determine when you want the next wash programme to start. This is particularly advantageous if you want to use night time electricity tariffs or if the programme needs to be finished at a certain time, for instance when you come home from work. You can postpone the start of a programme by up to 24 hours. The display also indicates when the current programme will finish.
Aug 04, 2017 | Washing Machines
I have a whirlpool dishwasher and I have pushed 1 hour wash and and start but the washing light comes on and then they start blinking and it won't start the wash cycle, any help would be greatly...
is that a delay to wash cycle? it sounds like it. My wash machine has that feature. Wait the hour and see if it starts.... Sorry that is all I can think it could be. Good luck!
Jul 30, 2014 | Dishwashers
Accidently pushed delay start, now annot wash
Hi sallysue5928 - How long was the delay start set to? Typically the delay time selected will be displayed as 30, 60, or 90 minutes or 2 through 14 hours. However, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it was unsuccessful then unfortunately you will have to wait till the time of the delay start cycle that was selected.
Feb 08, 2013 | Frigidaire ATF6000ES Front Load Washer
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Jan 04, 2011 | Dishwashers
Controller, door interlock and motor replaced. Unit comes on, but does not operate.
Hello Dave,
Welcome to FixYa.
Try this test I posted below and let me know what error you find...if any.
To begin the test program, press both the SCRUB WASH and DELICATE/ECONO wash program buttons at the same time
as you turn the unit on by pressing the ON/OFF button. Initially, the control unit version number will appear in the display
(e.g./ 20 = version 20, 21 = version 21, etc.).
When the wash program buttons are released, the LED's above them will begin flashing. To end the test program or test cycle, press the ON/OFF button.
To check the wash program LED, press its corresponding button.
To check the Cycle Countdown display, Refill Rinse Agent LED and REGULAR WASH button LED, press the REGULAR WASH button (press the DELAY START button to test the
Cycle Countdown display alone).
The Cycle Countdown display should show "88" when the DELAY START button is pressed and "8h" when the REGULAR WASH button is pressed.
To start the test cycle, press both the SCRUB WASH and DELICATE/ECONO buttons a second time.
When the test cycle has completed, the Cycle Countdown display will indicate a fault using the codes below. If a combination of faults exists, the code numbers will be added together, (e.g./ 6 = faults 2 + 4).
0 = No faults
1 = Aqua Sensor ("Sensotronic") fault
2 = Heating fault
4 = Filling fault
8 = NTC (temperature sensor) fault
email me at and I can send you via a "pdf" of the diagnostic/repair manual for your specific Bosch...provided it is indeed a SHU5316 unit.
I`ll watch for your reply. Good luck.
Macmarkus :)
Sep 30, 2010 | Bosch SHU5316UC Dishwasher
Dish washer does not turn on CL light stays on when reset count down 6 appears then goes to CL
Hello and welcome to Fixya,
I have a ton of service info on Bosch so it`s best I post you an exert from the service pdf`s I have on my PC which will explain the meaning of "CL" and then go from there. This is not a common indication of a control problem, but it could be a problem with the plastic casing which houses the control, we`ll deal with that later.
I`ve underlined the section pertaining to the "CL", this is for the SHU68** dishwashers only.
First depress the On/Off Button until it locks in place.
Once the On/Off Button is depressed the LED above the previously used cycle will illuminate.
To change the cycle, simply press the desired Cycle Button twice. The LED above that cycle will then illuminate.
The Cycle Countdown will display an approximate run time for the cycle chosen.
This run time will depend on incoming water temperature and the turbidity of the pre-wash water.
Note: It is normal for the Countdown Display to remain at a time increment for more than one minute, or skip a time increment depending on the calculations of the Control Unit. Also, with continued use the Control Unit will learn the wash and temperature patterns for the most commonly used programs and will then reduce the overall start and running times.
At the end of the cycle the display will show a CL, indicating that the cycle is complete.
Press the Scrub Wash and Delicate / Econo Buttons both in at the same time. The unit will then drain and the figure CL will appear in the display.**
The Delay Start feature allows the unit to be delayed for up to nine hours. To program, start the unit as described above, but after selecting a cycle push the Delay Start button. The display will show a 1h, or one-hour delay. Continue to depress the Delay Start Button until the desired delay time is reached (up to nine hours, 9h).
The unit will begin automatically once the delay time has elapsed. To reset the delay, press the Delay Start Button until it reaches 0h.
The Top Rack Only feature can be used in conjunction with any cycle. To active, press the Top Rack Only Button after selecting a
cycle, the Top Rack Only LED will illuminate and all water will be diverted to the upper wash arm for the complete cycle.
The Refill Rinse Agent LED is activated via a Reed Switch on the Detergent Dispenser, Section 4, Fig. 8-3. The LED will
illuminate when the Rinse Agent Dispenser is empty.
Service note: The Refill Rinse Agent LED will also illuminate when the dishwasher door is opened and then
closed even if the Dispenser is full, but will only remain lit for a few seconds.
An “F” in the display window indicates a filling fault.
Please note: If the door is opened during the cycle, the On/Off Button will be reset to off and must be depressed again to re-active the cycle. The cycle will resume from where it left off.
Now that you are equipped with this info, what I`d suggest is trying the **cancel option. ( ** see above )
Once you`ve tried the cancel option, select a Regular Wash and post back what happens and I`ll try to assist you from there.
Good luck.
macmarkus :)
May 14, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
Jun 24, 2007 | Bosch SHU5307UC Built-in Dishwasher
LG WM-1832C Front Load Washer Logo
195 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
