Question about Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo
Program timer button keeps flashing and when I push it the fm radio comes on. How do I get the tv to come on.
Cant get the TV to come on. Just goes to fm radio when I push the Program timer button.
  • 67 Answers
SOURCE: TV turns off
That sounds like a power board problem if im not mistaken where your power cord plugs into the tv there is a board it connects to often times if u plug the tv in and it starts itself or turns its self off its the power board that needs to be replaced which btw is not cheap at all
Posted on Mar 20, 2007
Orbixx
  • 133 Answers
SOURCE: panasonic ct-36hl43 tv
This is usually down to a safety feature cutting out the Television from harming itself. Or quite possibly a fault that make it turn itself off - it may well be thinking it's receiving the command to turn itself off. Either way, it's impossible to find out without opening it up. A professional repair is the only way, check up on your warranty. You may want to plug it into a different power source, just on the off-chance that it may solve your problem - but don't get your hopes up.
Posted on Sep 07, 2007
kevin000
  • 1847 Answers
SOURCE: lamp replacemant
chk this link....
http://www.techlore.com/forum/thread/19563/Pioneer-SD-533HD5-Green-light-flashes-then-back-to-standby/
Posted on Aug 08, 2008
  • 53 Answers
SOURCE: Television will not come on. Power light flashing red.
Hello Debbie ok the problem that your tv set is having is coming from the convergence board which is faulty and has to be replaced, you can find one at partstore.com or by contacting the manufactuer of the tv set they should have one in stock, change out the board and you should be seeing tv in no time thank you hope this helps.
Posted on Aug 27, 2009
  • 5 Answers
SOURCE: Power to TV, cant power on, red light flashing
The repetitive blinking light is a trouble code which is used to determine which series of boards may need to be replaced. How many times does the red light blink?
Posted on Aug 30, 2009
What is wrong with my samsung tv
Try pushing the source button on your remote after the red light stops flashing, Keep pushing the source button until it is on "TV". You may have set the remote to one of the aux settings by accident. My dogs do it to me all the time. Good luck.
Aug 28, 2015 | Samsung Televison & Video
I downloaded and installed the drivers for Philips SAA7130 TV Tuner/FM Radio/Video. The issue is, I cant get the TV program/ icon to run it. Kindly assist
did you install the software for the card set card for tv did you look at the manual it came with you need to set the tv on a line to be able to see it check the vcr setup for card jim
Dec 15, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
This program requires SAA7134 driver
Open this link (Click Here), look and wait for the countdown timer just below the "Premium Download" button to reset and click "Regular Download" to download the file. It's the drivers for your Tv Tuner card. You'll need winzip or winrar to extract the contents and install.
Let me know if you need further help.
Good luck.
Thanks for using FixYa.
Dec 06, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Fm-Radio problem
that model does not support radio.
Jun 21, 2009 | Audio Players & Recorders
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Zenith Z212B CD clock radio
Have you done the presets on the memory. Do that then select the station you want to wake up to. Hopefully its fm. Per the instruction manuel . Set or adjust the alarm time if necessary. Press the Alarm on/off button if necessary until one of the alarm indicatior either the note or alarm appears on display when the buzzer alarm is selected. While the alarm time display is flashing press the tuner button to select am, fm, or tv band. The selected indicatior appears in the display ( Note : you can only select the band when you have selected wake to music. While the alarm time display is flashing press one of the preset buttons to select the station you wish to hear when the alarm goes off.
Apr 17, 2008 | Audio Players & Recorders
Help ,help.
On- timer light flashing no picture no sound.
Dec 23, 2006 | JVC AV-32D502 32" TV
Panasonic PV-DM2792 Triple Play 27 in. TV/VCR/DVD Combo Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
