Question about Kenmore Freezer 13.7 cu. ft. Upright Freezer
My freezer won't stay cold
Model 253 9264212
Kenmore Upright Freezer Model #970180021 WB3285869Serial # I unplugged my freezer,plugged back said power interruption, I hit several buttons, Now flashing off, nothing else on panel lit up,thawing
try unplugging it and leaving it unplugged for a while. 15 minutes maybe? Leave door closed so it stays relatively cold. It should reset the unit.
Feb 01, 2018 | Kenmore Freezers
Freezer gets to cold thermostat won't adjust
Prepare to replace the t'stat. At least it is freezing and you haven't lost anything.
Jan 26, 2013 | Kenmore Elite Side By Side Refrigerator -...
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
Kenmore chest freezer model 12235 - won't get cold
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 13, 2010 | Freezers
Freezer running bout only freezer top of freezer
Either the compressor is failing or it has lost some freon which means there is a leak. The sealed system needs serviced.
Eric
Sep 15, 2009 | Woods Chest Freezer C1501W3
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezer not cold enough/ice maker not working
Check the coils in the freezer to see if they are blocked with ice.
May 01, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
Running non stop!
Sadly these old freezers use way too much electricity. You will be better off junking this one and purchasing a good used or brand new one.
Apr 02, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore Frost Free Comm. Model #253-23425100 - will not stay cold
Two things:
Either the thermostat has inadvertently been turned up, (too warm) or the gas in the compressor tank is low. If it isn't #1, call a repair tech to replentish the has in your compressor. If that isn't it he will tell you what he thinks it is. Good luck!
Mar 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore Freezer 13.7 cu. ft. Upright Freezer Logo
70 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
