Question about Welbilt MR95TW Microwave Oven
How do you adjust power settings?
Looking for way to adjust the power settings to a medium level rather than high on our microwave. Is this possible?
What is the output power of National NN-C2000P microwave oven?
the pwr rating is normally on the label.
google for a manual
Feb 02, 2016 | Microwave Ovens
I have a microwave in which i have option only for timer no option for setting temperature how to use it
Unlike a conventional oven, your microwave does not have a provision for setting a specific temperature. There may be only settings for different levels of heating such as high and medium and a special setting for thawing frozen food. The manual for your microwave could be a useful source of information regarding operation.
Dec 02, 2014 | In Microwave Ovens
How do I turn the mute off
I had this mute problem and found that unpluging it for 1 to 2 min. and the problem cleared.
Oct 05, 2014 | GE SpaceMaker Microwave Ovens
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Dec 12, 2013 | Microwave Ovens
What is the highest power setting? choices are low, defrost, medium, roast and reheat. no high???
Most microwaves run high at default, if roast and reheat are given that is your high setting, take one cup of water and run for 1 minute in each setting, the water that is the hottest is the high setting.
Mar 19, 2012 | Emerson MW8625W Microwave Oven
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
I have SUNBEAM microwave, model SM0701A7E--how do I set the power to MEDIUM? Thank you.
After a long search and reading I finally got it. To adjust power level follow these instructions:
1. Set timer for amount of minutes you want.
2. Hit "power" button"
3. Change the power from 100% to another percentage by hitting numbers 1-9
4. Press Start
Dec 22, 2010 | Sunbeam Microwave Ovens
Power on, everything sounds & looks normal but not heating food. When I hit power level option it does not say high, medium or low any longer.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 03, 2010 | GE JVM1850 1000 Watts Microwave Oven
Sanyo EM-P740w
It looks like you would enter the cooking time then press POWER 1 to 10 times. Once = 100%, twice = 90%, thrice = 80%, and so on, and "PL#" will appear in the display where "#" is the selected power level. On some models, twice = 80% and thrice = 60%, etc. and "80%", or "60%", etc., will appear in the display. Then press START. Did that do it?
Dec 07, 2006 | Sanyo EM-P740W Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top Welbilt Microwave Ovens Experts
William Miller
William Miller
Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
