Question about Protocol Predator SB 3.5-Channel Remote-Controlled Helicopter
Where does the power lead attach to hellicopter
Cant locate connection
I cant get hellicopter to charge
Maybe the battery is dead. Check the charging system/power supply. Maybe it's malfunctioning. Maybe inputs are wrong and check to see if they are working in proper order.
Jan 01, 2015 | Cameras
System powers up and doesnt do anything else. the fan goes really fast. no beeping at all
your computer is trying to connect to an operating system and cant find it
test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Aug 30, 2011 | Dell (58GGC) Motherboard
The whole screen just go blank, the power off, then off, the power button goes crazy, cant power on with the power buttons, but other buttons. but sometimes, stable, like NOW.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 28, 2011 | Computers & Internet
Can't load bios and chipset detected not working/not any warm but power switch and all fan working properly.
im not sure if you can or you cant but here goes
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
hope this helps
Apr 27, 2011 | ASUS P5LD2-VM Motherboard
I cant sucsses install window xp in d865gsa .first i use xp after some time i install vista and now i use w7 but i want now xp but sestem take cd boot and evrey thing on sacreen is black.whatcan i do now .
the first thing to check are the leads from motheboard to hard drive
test the leads tha are attached from your ((motherboard to your hard drive)) make sure the connections have a good seating or replace them including electrical extensions
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
make sure that the cd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
Apr 10, 2011 | Intel D865GSA (BOXD865GSAL) Motherboard
Even if the power cord and data cord is attached ,still i cant access my hard disk.
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 26, 2011 | Computers & Internet
My hd is being recognized in the device manager but it does not give it give location 0 chanel 0 target 0 i cant use it what can i do
hope this helps
Feb 02, 2011 | Western Digital (WD3200AVJS) 320 GB SATA...
Power supply is not on but power gets in and lights the light on the silicon board no cant power on the computer
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 17, 2011 | Dell OPTIPLEX 320 (MH651) Motherboard
I cant get the screen to come up? The power botton isnt even coming on, i have check the connections tried pushing the bottons on the side i can here it but cant get the screen up or even the power botton...
hope this helps
Jan 17, 2011 | Computers & Internet
Dell pc boots up and freezes when the DELL screen initially comes on. No power light comes on the keyboard; cant access bios, safe mode, etc. Solutions or suggestions?
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Dec 21, 2010 | Computers & Internet
Protocol Predator SB 3.5-Channel Remote-Controlled Helicopter Logo
66 people viewed this question
Top Protocol Toys Experts
scamatics777
Level 1 Expert
 Mikey
Mikey
 Russ Hill
Russ Hill
Are you a Protocol Toy Expert? Answer questions, earn points and help others
