Question about Vulcan EF3 Deep Fryer
Lots of yellow flame
Yellow and orange flames coming out of stack and out of door
Orange pilot flame
Orange or yellow gas flame indicates air is not being mixed with the gas before burning.
The pilot burner has air holes to allow air to mix with the gas for efficient blue flame burning.
The air holes are probably blocked if the flame is approximately the usual length or longer. If it is significantly shorter it indicates the gas pressure to the jet is reduced.
Feb 07, 2018 | Heating & Cooling
Flame burning too orange
You need to get a Plumber or Appliance Tech to come out immediately and check the fuel to air ratio. You are not burning your fuel at the proper mixture. A blue flame is good, yellow-orange is bad.
Normally this is because the burner area is dirty or the pressure regulator may be set too high/low. The black marks are a sure sign that your ratio is too rich and it's just going to build up more soot and become unhealthy and dangerous.
http://inspectapedia.com/plumbing/Gas_Flame_Noise_Defects.htm
Don't wait...
Mar 27, 2014 | Water Heaters
Orange flame
Not to be concerned. It is an indication that the burner is dirty. Try blowing it out with a blow dryer. If that doesn't do it, try brushing it with a medium stiff toothbrush. Brush it where the gas (flame) comes out. Then blow it out again.
Dec 15, 2013 | Blue Flame Heating & Cooling
Dynasty gas range - orange flames
It is normal, it will disappear after a little while, when you bang on the burners, particle fell off form inside of the burners and it caused the orange flame. Yellow flame means not enough air or burner is internal clogged.
Feb 15, 2010 | Dynasty DGRSC 36-6 Gas Kitchen Range
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Heater hasnt been used in a while. everytime It turn it on, lots of smoke comes out of the stack. Is that normal?
No. Spiders proably nested in the jets that force the gas into the burner tubes. Look under the burners with the heater on and find the tube(s) with orange/yellow flames.
Turn the heater off and clear those jets out. It should work frin from there.
Jul 04, 2009 | Hayward H Series Pool & Spa Heater 400k...
Orange flame color
Blue with orange tips should be fine yellow is 02 starved need to vent [good air movement]
Please rate. Thank you. jj505
Mar 27, 2009 | Whirlpool Water Heaters
Please send me cheats in guitar hero II
To unlock everything in the game, due the following code on your guitar at the title screen: Blue, Yellow, Orange, Red, Orange, Yellow, Red, Yellow, Red, Yellow, Red, Yellow.
Performance Mode ... YELLOW, YELLOW, BLUE, YELLOW, YELLOW, ORANGE, YELLOW, YELLOW
Hyper Speed ... ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE, YELLOW
Air Guitar ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, BLUE
Eyeball Heads ... BLUE, ORANGE, YELLOW, ORANGE, YELLOW, ORANGE, BLUE
Moneky Heads ... ORANGE, BLUE, YELLOW, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Flaming head ... ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE, YELLOW, YELLOW
Horse head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE
Air guitar ... BLUE, YELLOW, ORANGE, BLUE, YELLOW, YELLOW
Eyeball Heads ... YELLOW, ORANGE, BLUE, ORANGE, BLUE, ORANGE, YELLOW
Hyper Speed ... YELLOW, ORANGE, BLUE, ORANGE, YELLOW, ORANGE, BLUE, ORANGE
Monkey Heads ... YELLOW, YELLOW, BLUE, ORANGE, YELLOW, YELLOW, BLUE, ORANGE
Flaming Head ... YELLOW, YELLOW, ORANGE, YELLOW, ORANGE, ORANGE, YELLOW, ORANGE
No HUD performance mode ... YELLOW, YELLOW, ORANGE, YELLOW, YELLOW, BLUE, YELLOW, YELLOW
Horse Head ... BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE, ORANGE, BLUE, ORANGE
Jan 06, 2009 | RedOctane Guitar Hero 2 Game For...
Vulcan EF3 Deep Fryer Logo
43 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
