Question about Air Tools & Compressors
Lower PSI MF Master Elite air compressor 1hp model
hdpanama
  • 65 Answers
SOURCE: My air compressor is running, but there is a little bit air
Pistons may have lost their seals and not compressing the volume it needs. It's not turning off at 40 correct? That would be the pressure switch. Oil lubed probably like taking a small gas powered engine apart. Check the walls for scoring and such. If none to deep you can get an attachment for a drill to hone them. Auto parts will have that, parts depend on how old but should be at if you have like Sears Appliance repair stocks many different parts for what not. VERY expensive to let them do it but is an option for you. Make sure you have specs for torque and such for the bolts. And your sure no leak or pressure relief valve, yea you would hear that. I wish it was something else.But that's all I can think it would be if it's running continuously.
Posted on Nov 20, 2008
inhisname
  • 76 Answers
SOURCE: the air is coming out of the filter
if acualy exhaust / engine pressure is coming out of filter it likely to be a bad valve...does engine blow smaoke or oil? is there also pressure coming out of oil crankcase?....let me know , we'll diagnose it! good luck, marty
Posted on Jun 14, 2009
dmftrucker
  • 1922 Answers
SOURCE: air leaks between head and cylinder
either the head gasket is gone or the rings are shot
Posted on Oct 06, 2009
  • 4088 Answers
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
Posted on Jan 18, 2010
SOURCE: Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Posted on Feb 15, 2010
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
Can i lower my air pressure down to 18 psi on my compressor
Where the airline is attached to the compressor it should have a regulatorand gage that allows the air pressure to be turned down.
Jan 26, 2015 | Psi Air Tools & Compressors
Master elite 1 hp hush series
Im assuming you want lower air line pressure,the best thing for you is to get a air pressure regulator and install it between the compressor outlet and you air line which has a knob to regulate air line pressure
Mar 22, 2014 | Air Tools & Compressors
How to take the top off mf my bosttitch 6 gallon pancake 150 psi air compressor
the should be a bunch of phillips head screws and 2 flat heads deep inside it
unscrew and it will come apart
Jan 04, 2014 | Stanley Bostitch 2hp 6gal Air Compressor...
I have a central pneumatic compressor 21gal 2hp a couple years old the unit runs but will only pump up to 75psi and keeps running and does not build more pressure.It was building up to 110psi and then it...
Its the pressure regulator, if you discharge the air and can set the regulator to a lower psi, and it pumps
to that psi. you will have to replace that part, make sure to have make, model , serial# of compressor
so that the correct part can be fittted to you compressor. good luck!
Jul 31, 2011 | Air Tools & Compressors
I have a model cw0100 1hp 4gal. and need to know capacity of oil tank.
Check you model number. I don't think cw0100 is correct. Most 1HP 4 gal pancake compressors are oil-free.
Jan 09, 2011 | Stanley FactoryReconditioned Bostitch...
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
1hp 4gal 2 tank Craftsman Air Compressor not Compressing
Try emptying the tanks completely. There should be a bleeder valve for each tank. Sometimes after sitting for a while with pressure, the compressor won't have enough power to start. If you get the same response with empty tanks, there is a problem with the pump pistons.
Dan
Jan 11, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Air Tools & Compressors Logo
35 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
