Question about Dual Electronics XDVD9101 Car Video Player
Lost code to xvdv9101 radio
Changed battery and now radio won't play, how can I find the code
2002 bmw x5 3.0, changed-out battery & lost audio on radio (factory stock ).visual display ok.
You need to have the anti-theft code put in to make the radio work, this happens when the battery power is lost. Call the dealer or go to www.radio-codes.com
Mar 08, 2016 | BMW Cars & Trucks
How can I get the radio code for bt 50
Hi, few options:
1) go to a Mazda Garage.
2) insert 3 times the wrong code and then follow: http://www.mazdaforum.com/forum/general-tech-6/mazda-radio-code-reset-15083/
Dec 09, 2014 | Cars & Trucks
Lost ford transit radio code
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Mar 13, 2013 | Car Audio & Video
Battery went dead, jumped to start, now radio won't play, word CODE came up in little screen above radio, Help
it is most likely that the radio had an anti theft security code activated & until you re activate the code the radio will not work......hope this helps.......cheers.
Sep 08, 2011 | 2000 Mitsubishi Eclipse
Replaced the battery & now the radio/cd player
Your radio will need a code to reactive it because the power has been lost.
You need to post up the serial and part number of the radio - found on a label at the back so you will need to remove the radio from the dash to find this.
Make and model of radio and car also required. Then we can advise further.
Thanks for using fixYa.
Aug 26, 2011 | Car Audio & Video
My battery died so i replaced it and now my radio won't come on. Tried holding down power button, turning on and off ignition. Still has no power. the battery was out of the car for about 4 hours.
If your radio has anti-theft system you will have to go to the dealer and get the accss code to reactivate the radio if you dont have the code already. GM vehicles with anti-theft radios will lock when power is lost to the system if the radio is not turned off prior to battery disconnect or dying.
Jul 24, 2011 | 2005 Chevrolet Cobalt
I need a radio code for a honda accord 2005 vin 1hgcm72745a000056 and serial number 12261212
I don't think you will find this online; the dealer can find it for you but probably won't do it free.
If you lost the radio because of battery change or disconnect, you can prevent this from happening again with a cheap, simple device that uses a standard 9 volt battery and your cigarette lighter/power jack, to supply 'keep alive' voltage while disconnecting the main battery. Auto parts stores carry them.
May 22, 2011 | 2005 Honda Accord
2001 Mitsubishi Monteo Sport radio/CD lost functions?
I have seen this before, You should pull the radio out and get the serial number off of the back. Call your dealer and get the radio code. Disconnect and reconnect your battery and input code given by dealer. Usually this occurs when you change or let the battery rundown, it is an antitheft feature. Most of the time you would lose all functionality but in your case there may have been some kind a electrical surge that tripped part off your radio functionality. Please let me know if this works for you.
Feb 27, 2009 | 2001 Mitsubishi Montero Sport 4WD
2001 Mitsubishi radio lost ability to change radio stations
just unplug the battery for about ten minutes to reset it. make sure you have the code for the radio if it needs one.
Dual Electronics XDVD9101 Car Video Player Logo
Top Dual Electronics Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
xxxxxx xxx
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
