Question about First Alert 24 Hour Timers - 2 For The Price Of 1
24 light timer mod nr 0641
0641
I need a night light timer that I can set to be on for 50 minutes and off for 10 minutes and repeat this every hour for 24 hours.
1) If you have programmable timer, then it would require 24 ON and 24 OFF settings, with down-to-the minute programming.
1 ON for each hour.
1 OFF for each hour.
Following link shows Grasslin 50-60 Hz 230Volt din rail timer with 50 memory slots. 16 amp at 230 volts
http://waterheatertimer.org/pdf/talento_371_372_371_mini_plus_data.pdf
2) If you have 24 hour mechanical timer with dial, it would need 24 ON trippers and 24 off trippers with down-to-the minute schedule.
No timer has that capability.
3) There is C8800 series cycle timer. 120-240Volt 60Hz for US market. 20 amp at 120volts, or 20 amp at 240Volt. Chose 1 hour cycle, then insert 100 trippers and leave 20 blank spaces.
http://waterheatertimer.org/pdf/027-C8800-sprinkler-cycle-timer.pdf
4) There are percentage cycle timers.
For example CT2000. Rated 120Volts 60 Hz for US market.
http://waterheatertimer.org/pdf/CT2000_sell-sheet-with-wiring.pdf
Select 1 hour cycle, and 16% or 84% percentage to choose ON or OFF
Nov 28, 2012 | Woods Indoor 24 Hour Night Light Timer...
Directv remote code for viera tc-32lc5
Check these codes;
0622 0632 0629 0621 0623 0576 0586 0616 0613
0630 0634 0636 0638 0641 0652
0653 0657 0659 0607 0619 0641
May 05, 2012 | Directv Televison & Video
I need to connect my apex digital converter box to my all for one urc 4021 and i need the code to do so
Try these codes.
Apr 29, 2012 | Televison & Video
Lista de codigos
0622 0632 0629 0621 ................. 0623 0576 0586 0616 0613
....... 0630 0634 0636 0638 0641 0652
....... 0653 0657 0659 0607 0619 0641
Apr 23, 2012 | DISH Network IR Remote Control
Tv codes for a DTA800B! converter box
Apr 10, 2012 | Televison & Video
Direct tv remote code for yamakawa DVD-218
Try these codes
Mar 24, 2012 | Televison & Video
Codes for starview 7
Try these codes.
Mar 24, 2012 | Sony Televison & Video
I need the GE universal remote code to apex dt250a converter box
Just bought GE universal remote 24944. Code 2911 works for my Apex DT250A converter.
Mar 23, 2012 | GE Televison & Video
General electric 24 hour timer ge5101n can it be used uith cfl (compact Floricent Lighting)
ge5101 can be used with cfl
The timer turns the circuit on-and-off like a light switch.
Anything a light switch can turn on, a timer can turn on.
Oct 08, 2010 | Solar Ge 24 Hour Timer 2 Pk (ge24t)
First Alert 24 Hour Timers - 2 For The Price Of 1 Logo
Top First Alert Hardware & Accessories Experts
Gene Haynes
Tom Chichester
 Mikey
Mikey
Are you a First Alert Hardware and Accessory Expert? Answer questions, earn points and help others
