My tascam does not play
SOURCE: wont play songs
I get the same problem with my Sansa e280. If you find a solution, can you post it? Thanks, Jim
SOURCE: tascam dp-01fx system 50 error
what the above guest said is exactly what you need to do. Make sure of course there is nothing on your FAT(previously exported songs/masters) because they will be erased. just go to menu->disk->fat reform, then press enter
SOURCE: Low volume on finalized songs.
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
SOURCE: Snapbox X-25 (2GB) MP3-MP4 Player songs are playing slow
i don't know why when i record video it doesn't record videos
so what is the problem it' not recording the type of the video i wanted
so i need the video type for the snapbox ipods
SOURCE: re: Tascam dp-02 8 track
It happens all the time to me. Only solution is to save constantly as you record because once it freezes up and says not stopped you can only unplug and plug back in then turn power on. You will lose what you were recording but nothing will be lost that you have saved.
