Question about Verona FSGE536SS Dual Fuel (Electric and Gas) Kitchen Range
ELECTRIC OVEN NOT HEATING
TOP AND BOTTOM ELEMENTS NOT HEATING
I have Technika oven and both top and bottom elements are not heating. Both dials show red light for power on though not heating.
The red lights may be indicating power is being applied to elements that have failed. It seems an odd coincidence that both elements would fail at the same time.
Jan 27, 2017 | Ovens
How to repair an electric oven that won't shut off?
call an electrician to test the switches for faults or the circuits for a problem
possible a loose active wire touching where it should not be from rotting insulation or loose screws
Sep 17, 2016 | GE Profile JDP47 Electric Kitchen Range
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
HEATING ELEMENTS
The heating elements are inside on the top and bottom
Jun 08, 2013 | Bella Cucina 13049 1500 Watts Toaster Oven...
Are the top and bottom heating elements both supposed to heat? Only the bottom one is heating except when specifically set on "broil".
Most ovens with top and bottom elements have a multifunction control switch which enables the user to select a certain setting to suit their cooking. The control switch would normally have small pictures of the elements, fan forced function etc, to show what each setting does. Sometimes you may only require the bottom element working and other times you may want/need both.
Feb 14, 2011 | Frigidaire Ovens
Ge double oven, no heating
check that u have continuity through the elements if you dont then replace the element next if you do have continuity through both elements check to make sure you have power coming from the main control to the element if you dont have any power leaving the control board then replace the control
May 18, 2010 | GE Profile JTP56 Electric Double Oven
The oven heats up very slowly
Yes...
Check out this tip that I wrote about this problem...
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 30, 2010 | Whirlpool RF364 Electric Kitchen Range
Verona FSGE536SS Dual Fuel (Electric and Gas) Kitchen Range Logo
26 people viewed this question
Top Verona Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Verona Kitchen Range Expert? Answer questions, earn points and help others
