Question about Avanti Hot and Cold Water Cooler
Water cooler flooding
Will not accept new bottle of water without flooding
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
We have a true upright, glass front beer cooler. TBB-4-G refrigerated back bar. The bottles and cans right in the middle are icing up and forming huge blocks of ice. we have turned up the thermostat,...
Check your evaporator drain pan and the outlet for the condensate water, and make sure the drain tubing is clear. That water is supposed to drain outside the box.
Aug 30, 2011 | True TD-95-38-LT Beverage Cooler
I HAVE A G.E. SMART WATER COOLER THAT LEAKS WATER FROM UNDER BOTTOM BASE I HAVE TO KEEP A TOWEL ON THE FLOOR UNTIL ITS GETS SOAKED THEN I CHANGE IT, USUALLY OVERNIGHT, I'M USING A 5 GAL. BOTTLE...
try replacing the bottle...it might have a hairline crack that is causing the "leak". I have the same cooler and had the same issue...replaced the bottle and all was well then.
Roy Martinez
Jan 12, 2011 | General Electric GE SmartWater Household...
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
GE Water Cooler Reservoir overflows.
There should be no crack or pin hole in your water bottle.
Water bottle should be air-tight to make proper pressure inside bottle.
Whenever lose pressure, water overflow with no bubble.
Just replace water bottle with no crack or pin hole.
Good luck.
leey05
Jan 07, 2010 | GE Refrigerators
After emptying our water dispenser for cleaning,
Good luck.
leey05
Dec 07, 2009 | Hamilton Beach Water Cooler with Storage...
My water cooler runs but it doesnt cool anymore, is it worth fixing, its about 5 years old. It a unit that holds a 15litre bottle
Hello. The sad reality these days is that a service call is generally going to cost you about $100. or more. You can purchase a new and much more efficient cooler at a box store for a very low price. AND, many bottled water companies give you a loaner cooler if you have them deliver the water to you.
Nov 11, 2009 | Refrigerators
Advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
Substitute water refill..
I'm not sure what you're asking. You can run a plastic tube from a faucet head to the reservoir of this water machine - liable to get messy/wet if not handled properly. You can also puncture a hole in the water bottle - toward the bottom (careful) and tape a plastic tube from the water bottle to nowhere - be sure to tape the end shut so you don't experience leakage - will get annoying over tiem.
Just call the manufacturer/distributor - if they can't fix it or replace it under warranty, just buy a new one.
May 30, 2008 | Avanti Hot and Cold Water Cooler
Avanti Hot and Cold Water Cooler Logo
43 people viewed this question
Top Avanti Water Filters & Coolers Experts
John Tripp
John Tripp
john h
Are you an Avanti Water Filter and Cooler Expert? Answer questions, earn points and help others
