Question about Peavey Escort 5000 Escort 5000 PA System
How to connect a Peavey wireless mic receiver to a Peavey Escort 5000
Trying to connect the wireless mic receiver to the Peavey Escort 5000 Escort 5000 PA System. Which port does it plug into?
SOURCE: Peavey Escort system
would you like to sell your system i need parts
wete502764@aol.com
Posted on Feb 11, 2009
  • 4 Answers
SOURCE: Mic feedback.
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Posted on Mar 22, 2009
  • 88 Answers
SOURCE: how do i connect the cables between peavey vocal
if you mean effects loop try graphic out to ultraverb input and output to power amp in. this will effect all channels of the xr500c
Posted on Feb 04, 2010
  • 5603 Answers
SOURCE: the power of the Peavey Escort 3000 Portable PA
A failure probably occured in one of the power amps and has blown the fuse or worse. DO NOT replace the fuse and try to operate it as further damage may occur. Take it in for repair.
Posted on Feb 16, 2011
bobhifi
  • 635 Answers
SOURCE: Useing a Peavey XR 800F
First of all confirm if the speaker impedance is not lower then the recommended Ohms at the back of the Mixer speaker socket.You can use an 8 Ohms speaker on a 4 Ohms amplifier but not vise versa .
Next see if the fan on the mixer works. If not the Amp is getting very hot and this will lead to unwanted distortion. You can confirm if its a heat related issue by playing the mixer at low volumes for more than an hour and see if it distorts.
Posted on Apr 26, 2011
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
How do I connect my wireless mic to my karaoke
Simply connect the mic-level output from your wireless mic receiver to the mic input on the karaoke system.
Oct 19, 2014 | Audio Players & Recorders
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey escort
I would try unplugging some of the extras. All of that could have been causing your line voltage to sag too low for the mixer supply to operate properly.
Jan 17, 2009 | Peavey 00511800 Escort Portable Sound...
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
Repair manual or schematic
nesecito la numeracion de los integrados de potencia para peavey escort 2000
May 21, 2008 | Peavey Escort 2000 Microphone
Low volume from CD and iPod input
in audio system you have three different levels.
1-mic level which is very small output level.
2-line level(like cd player output)which is higher than above.
3-speaker level is highest one which drive speaker and get sound out from it.
if you want to get control for number 1 and 2 you can use very simple sound mixer.(from radio shack-or other electronic store)
connect your sound source(mic-cdplayer)to the mixer and get out from mixer to amplifier.
Jan 23, 2008 | Peavey Escort 2000 Microphone
Want work
You need to fine tune (to connect wirelessly) ur wireless mic to your wireless receiver unit. Put a fresh battery to ur Mic then power-up ur receiver unit, find the right channel for both unit.
Aug 05, 2007 | Audio Technica Audio-Technica DR2600...
Peavey Escort 5000 Escort 5000 PA System Logo
70 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Jaime Hernandez
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
