Question about Garden
Craftsman 247.288820 tire pressure
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
What tire pressure for a craftsman lawn tractor
It should be written on the tire sidewall. If it has worn off, it is also written on the inner side. Use a digital camera to take a photo on the inner side. Depending on the tire size they are around 14 psi front and 10 psi rear. Lower pressures are better for grip and less prone to puncture. Be careful these tire inflate quickly and can burst.
Jun 06, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
The deck on my Craftsman mower is touching the ground on the left side. Help!
IF THIS IS WHAT I THINK IT IS .. IT'S A EASY FIX.. YOU HAVE LOW AIR PRESSURE IN ONE OR ALL OF YOUR TIRES..
Jun 23, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Sears evolv 3 gal air compressor that will not inflate a auto tire, even a partially de-flated tire. I let the pressure build to 100 psi and checked all fittings. Still wil not do it. Compressor...
The evolv air compressor was primarily designed to power a very small nailer. The pressure regulator (knob in front) should be turned clockwise till it stops to attain full pressure. At this setting it should air your tire. If not you may have a defective regulator. There is a trick to get full pressure from your tank. Notice the small pressure safety valve on the side of the unit. You could remove this valve and install a fitting giving you two ports. One for the safety and other for a quick disconnect. This second port will give you access to tank pressure without going thru the pressure regulator. This mod is safe because you still have access to regulated pressure when you need it. Good luck
Jul 07, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Cuts lower on side
first and foremost! make sure the tire pressure is correct in ALL TIRES and then level the deck.
May 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a Craftsman Air compressor 919.150380. My tire needs air. My husband passed away 3 yrs. ago, and I don't know how to operate it. Can't find owner's manual or one online.
Attach your hose and tire filler. They should be a "quick connect". Take the larger fitting and kind of slide it back and insert the smaller fitting. Let go of the slide and pull to make sure you have a positive connection. It will be easier to connect everything when there is no air pressure. There should be an on/off switch located on the right if the tank is facing you. Plug it in, turn it on and wait for it to fill up. Depending on how much air you need, you might have to put some in and then let the compressor cycle back up to its high pressure.
Let me know if I can help you further.
Mike
Jan 28, 2010 | Craftsman Air Tools & Compressors
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Gauge says tank at 120 lbs of pressure, but won't fill tires
sounds like you have a bad batch of schrader vales on your tires OR
you have a defective chuck end that is not milled properly to push the schrader valve and let the air into the tire stem
Jul 05, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman compressor
They put this under vacuums, relist it in the right place.
Dec 16, 2007 | Porter Cable 7812 Wet/Dry Vacuum
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
