Question about Garden
Where is the fuse box on a 1720 ford tractor?
I have a 1995 Ford model 7740 SL the PTO will not engage it was working but kicking out so I replaced switch didn't work so then replaced module in fuse box as well as the fuse still nothing all that's...
I would suggest investing in a service and repair manual for your tractor; here's a helpful link: https://www.tradebit.com/filedetail.php/274757894-ford-new-holland-5640-6640-7740-7840
This way you can get all the electrical voltage and resistance specs for the components you need to test instead of using the process of elimination method that could end up being as costly as bringing it to an authorized repair shop...and eliminate the frustration factor in DIY projects.
The link I posted was not to promote this vendor; and I certainly have no personal or financial interests with this company; I'm just trying to be helpful and pass on good info. You may have your own local tractor dealer that can get you a similar type service & repair manual as well.
In the meantime, I would check my voltage and resistance readings on the switch, fuse, relay, and solenoid components and call the local repair shop to get the range specs on each.
Best regards on your project.
Feb 23, 2015 | Ford Garden
Ford tracktor 1720 how do you check hydro-lick level
there should be a place on stick to see if safe or not
Aug 28, 2014 | Ford Garden
Can't get my working lights to come on
If you have power to the fuse box, measure with a multimeter to see how much you have from the battery, then to the fuse box... Then see how much leaving the fuse box, if there isn't any power leaving the fuse box,,, you have a faulty fuse box or a possible bad connection (ground) if you have power check the relays, often you relays go bad, you'll hear them flicker but the don't actual make the connection to give voltage to the lights... Also you can test the voltage at the light bulb socket with the power on and switch on with a multimeter..
Nov 16, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere 6400 no power
CHECK MAIN FUSE IF THE FUSE BOX IT IS THE FIRST ONE AT THE TOP IF YOU LOOK IN THE I THINK IS M1 FUSE 30 AMP
Oct 09, 2012 | John Deere 6300,6300l,6400,6400l Tractor...
How do i change cigarette lighter fuse on a ford focus 2012
ford focus 2010 - fuse box located underneath glove box passenger side. two black turn screws - turn 1/4 turn to release white fuse box. Cigaretter lighter fuse is fuse number 109 (difficult to see as white text on white box!!!)
Fuse is 20A fuse located first left on second row as indicated in diagram.
Sep 07, 2012 | 2012 Ford Focus
Where is the fuse box on the toro lx 425 lawn tractor
MOST LAWN TRACTORS DO NOT HAVE A FUSE BOX. SEE IF THERE MAY BE A IN-LINE FUSE.
May 26, 2012 | Toro Garden
Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Apr 11, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
