Question about Diesel Lionel Nascar Gp38 Locomotive Engine
TRAIN SOUNDS TAKING APART SPEAKER COVER
Micromax speaker repair
You can open up the side cover to ensure that if the speaker jack is porperly plugged in or not because it sometime happen because of taking anything apart.
Sep 18, 2013 | IBM eServer xSeries x226
When i turn speaker on my phone ON, the phone dies afer 5 seconds ,and the call disconnects.after a while a phone is fine and works ok otherwise.only problem is with the speaker.
Sounds like maybe your speaker is shorting something out. I've seen this before with certain cell phones. Unfortunately other than taking the cell phone apart there is no other way to fix it. If you are comfortable taking the cell phone apart then do a visual inspection on all the wires/solder joints surrounding your speaker. If anything is loose.. it needs to be reconnected.
Apr 05, 2011 | Lands Phones
No sound coming from driver door. Have sound
Speaker wires often break where they flex near the door hinge.
But all door panels are mostly plastic snaps around all the edges but the top. The tops always hooks on and requires lifting upwards. But you can't do that until you take off the handles, etc. They usually have screws that you can uncover by taking off cover plates.
Apr 04, 2010 | 2004 Chevrolet Avalanche
Need help taking apart a sony sa-va100. One of your experts nealpj1 has taken one apart and he mentions ''Just like the processor, you will have to replace the grease or hear sink liquid'' I want to try...
Not sure what replacing the heat sink grease will do? You may have missed a few screws that are under the speaker grill cover / front control fanel. It is a tricky one to take apart.
It does have a common solder failure on the outputs and regulators.
It's been a couple of years since I last repaired one.
Feb 10, 2010 | Sony SA-VA100 System
My phone a Motorola w370 was thrown across the room (not by me)it turns on to a blank screen, can still make receive calls however I can not hear the other person... they can hear me just fine. it is...
It sounds like a problem with the phone's speaker. There is chance the contact might have cut off. You can try taking it to a service centre, because it sounds like a minor issue.
Hope this helps :)
Oct 24, 2009 | Motorola Mobility W370 Cellular Phone
2000 vw passat 1.8lt 164 000 km,knocking noise on top end
YES IT IS IN THE VAVLE TRAIN COMIN IN MOST VW THE TIMING CHAIN ADJUSTER GOS BAD MOST OF THE TIME FROM LACK OF OILCHANGES AND OR CHEAP OILS ANY WAY NEED TO REPLACE GO TO REPAIR SHOP VERY HIGH TECH JOB
Aug 12, 2009 | 2000 Volkswagen Beetle
Same here, completely silent
sounds like your external speaker has gone out... you might want to check the waranty information with your carrier. If the carier is AT&T you have a 1 year warranty from the original purchase date. This is a problem that cant be fixed without taking the phone completely apart and replacing the speaker.
Aug 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
Where do I put the battery for the HIT motorized Thomas train
i will try my best to help, i had the same problem with my sons as well..i was in the same situation:).You have to take the top of the train and the bottom of the train apart, seperate the top & bottom,then the battery compartment is inbetween the two..sounds confusing i know..they are very hard to pry apart.Hoped I helped!
Jul 06, 2009 | Hit Thomas and Friends Trackmaster...
I just bought some pioneer ts-w305c subs from some guy in canada and one of them is sounds distorted< when barely playin it buzzes can u help me?
This could be either the speaker that is blown and making the noise or part of the amplifier being smoked causing distortion that sounds like a blown speaker. WIthout taking it apart and looking at waveforms on an oscilloscope, I can't tell you which is the problem. I'd ask a local shop to test it for you or if you can, exchange the actual speakers between the two. IF the problem stays with the bad box, the problem is with the amp, if the good speaker works OK in the "bad box" then the speaker is blown.
Keep us posted.
Dan
Sep 05, 2008 | Pioneer Audio Players & Recorders
Diesel Lionel Nascar Gp38  Locomotive Engine Logo
Top Diesel Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Diesel Craft and Hobby Expert? Answer questions, earn points and help others
