Wiring diagrams Acoustic Energy 3311 Speakers
2 Suggested Answers
STP162
  • 132 Answers
SOURCE: how to wire in a cross over
You didn't say if it was active or passive, but here is both:
Passive crossovers are easy to install. By definition, the only type of connections they require are to your speaker line. They typically get installed between the end of the speaker wire and the speaker. Connection should be fairly simple, just like hooking up the speaker itself.
Now F-Mod crossovers modify the audio signal before it is amplified. They accept the patch cord from your receiver on one end, and then plug directly into the preamp inputs on your amplifier. They are also easy to install, and don't require additional wiring.
 An active crossover requires a little more work. You have to connect 12-volt power, ground, and a turn-on lead. The active crossover gets installed between your receiver and your amplifier. A lot of active crossovers have both speaker-level and preamp inputs, so they can usually work with either type of connection. The outputs will be preamp connections to your amplifier. Hope that helps.
Posted on Oct 22, 2007
There are 2 wires from crossover to Acoustic Research Phantom 8.3 Titanium Tweeters. One wire is Brown, other Green. Tweeters have one terminal marked with red paint. Some of my speakers have Brown wire...
Normally Speaker and Amp side will mark correctly the polarity. If wrongly connect phase may get wrong. If you understand or may know the different by hearing, if both tweeter phase is wrongly connect, what need to do is reverse the connection of one side the phase will change. you can try which give you the best listening feeling.
Feb 08, 2013 | Acoustic Research Phantom 8.3 Main /...
My acoustic energy wifi radio does not link with any wifi service. Any ideas?
hope u have turned on wifi device as shown to all..
let check wether wifi device has no tech issues
Dec 19, 2012 | Acoustic Energy WiFi Internet Radio
Where can i find a wiring diagram of a boston acoustic pc speaker
you can compare the color of male plug agains PC female input....green on green, blue in blue etc..
May 23, 2010 | Boston Acoustics BA735 Computer Speakers
Subwoofer hums when on. Hum persists when speaker disconnected from amplifier. Gets louder if volume turned up. Is this a service issue or am I picking up interference from power line.
1-check your connection cable for good condition and change it with new one.
2-insert(ground-loop isolator)(radio shack(270-54).between your audio out and subwoofer
Nov 27, 2009 | Acoustic Energy Audio Players & Recorders
How to wire acoustic solutions AS134
how many cables shud link up to the tv with the acoustic solution model AS134?i have the colour coded pins plugged in to the speakers left,right,back left,back right and center which plug in to the subwoofer box.how ever i then only have 1 cable left which has a red pin and a white pin that i assume go into the AUX left and right pin ports?the cable then splits into another 2 red and white pins.do these pins plug into the left and right output on the tv?am i missing any cables?help would be appreciated.
Jul 19, 2009 | Acoustic Solutions Audio Players &...
Wireless speaker won't come on after plugging in now....
Try the adaptor that you know works in the speaker that doesn't. That will eliminate if its the adaptor or the speaker. You will need a multimeter to check if its the on /off switch or not. A quick alternative is to "bridge" out the on / off switch wiring. (Use a piece of wire to join the wires going through the switch together.)
Sep 04, 2017 | Acoustic Research 900MHz Wireless Stereo...
21 people viewed this question
 Grubhead
Grubhead
