Fisher paykel aqua smart clothes washer too many suds
The machine keeps saying 'too many suds' but I have added just water and tried to use just spin and turned it off for about an hour and also completed two washes without soap. I have also done two clean bowls one with CLR and one with washing liquid
    Novelist:
  • 167 Answers
You have a bad sensor, it is out of tolerance and giving you a false reading. If you have the paper work on it look and see if it has anything on the 'suds' indicator or go to the factory web site. A lot of times you will find others have had the problem and you will be able to find the solution there. If not go straight into the factory site and try to get a factory technician to tell you what to do. You can buy a new washer for what a service tech will charge you to come out now days. If you can't find any answers get back with me and I will research it from my end and try to give you exact instructions myself.
Col. Dana Gillespie
Posted on Mar 23, 2014
fanny
  • 146 Answers
SOURCE: fisher paykel washer
The drain pump is jammed. Switch off and remove the plug from the wall socket. Tilt the machine back so you can look under it. On the right you will see a motor which looks like it is upside down. This is your drain pump. Remove the wiring harness from the pump and turn the pump clockwise while pulling back the little white plastic clip which holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
SOURCE: 'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
ALL THE BEST!
Posted on Feb 23, 2009
SOURCE: Aqua Smart washer says, "clean cycle" need after 125 washes. How do I do that?
It's under the "lifestyle" section of the wash selection menu. It was called "Clean me" on my machine
Posted on Jun 20, 2009
BIKER T
  • 909 Answers
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aqua smart fault 49
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
Nov 26, 2012 | Fisher and Paykel Washing Machines
Fisher@paykel aqua smart washer shows fault code49.
Fault 49 on F&P agitator models is bad cold water valve or wires on it disconnected.
Apr 25, 2012 | Fisher and Paykel Washing Machines
I have an toploader smart drive (about 12 years old now). I added some clothes to the machine last minute throught the cycle and now its just stopped. Dashboard lights come on but it wont drain or...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 21, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Warning I have too many suds
Hi just read your posting.Now just a couple of questions.1st where is the machine draining the water to?Is it into the laundry sink or to another place?Have you removed the clothes from the machine?Have you tried putting a bucket or two of water manually into the bowl and put it to a spin cycle to drain the water out? Please reply with additional information and I can help you further.
Jul 06, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Too much detergent,how fix sud problems
OK-- 1st turn machine on and advance the cycle to spin 2nd open the lid and pour a bucket of water into the bowl. 3rd-- shut lid and push the start button. keep repeating these steps until the suds have dissipated.the reason for the suds not draining is the pump will not pump out soap and you have to mix the suds with water for the pump to be effective.hope this helps please reply to let me know how you got on.
May 25, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel gwl11 want power on
Start of by replacing your drain pump. if there is still no response to the electroncs you will need another power supply. the pump took the electronics out. ???
Aug 02, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
