Question about Sony KDL46BX450 - 46 inch 1080p LCD HDTV [KDL46BX450]
Horizontal lines across screen of sony KDL-46BX450
Horizontal lines appear across the screen. The lines jump around and create shadows on the screen
ginko
  • 19396 Answers
SOURCE: Sony Bravia TV KDL-V32XBR1 picture
Try different cable, if you still get the problem after replacing cables, then you have a defective sygnal board (input board).
Posted on Dec 13, 2008
welcomejee
  • 10594 Answers
SOURCE: KDL-40S2000 horizontal black lines
Seems T-Con board mounted at top center at rear of LCD Panel is bad.
Local TV tech will fix TV by replacing T-Con board.
Thanks.
Posted on Aug 30, 2009
roety
  • 585 Answers
SOURCE: thin vertical line runs across the top of screen
Hi my name is Roety,
I can help you with your issue ,
 Try the format, aspect buttons on the Box remote, if the line is there on every input and effect the TV menu your panel (screen) is bad.
A new panel would cost as much as a new TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Oct 24, 2009
SOURCE: Sony kdl-v40xbr1 has horizontal lines
I'm having the same problem. I have noticed on mine that the menu when brought up is clear and I can see it perfectly. The picture on all the inputs is just as described above though. BUT, like I said I can see the menu just fine. This leads me to believe that it's not the panel. Anyone have a solution to this, or at least know what could be causing it?
Posted on Sep 24, 2010
SOURCE: have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Posted on Oct 18, 2010
A small horizontal line going across the bottom.Now a horizontal shadow appeared above the line.Each day a new shadow appears & lighter then the rest.Now a thick box of silver/purple lines at bottom.
Seems like back-light fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 12, 2016 | Televison & Video
My KDL 46HX820 has lines from left to right horizontally
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 20, 2015 | Sony Bravia Kdl46hx820 Led Hdtv 1080p 46...
Sounds like a T'Con fault itself. Re-seat all the incoming and outgoing flat cable wires to T'Con. If it do not help you, replace it with a new one of same part number. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
Horizontal shadow line
It sounds to be a back-light fault. Check the backlight inverter board, and back light. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Nov 30, 2013 | Sony BRAVIA KDL-46W3000 Television
What causes horizontal lines across tv screen
The horizontal lines on the screen is a symptom of failing LCD panel, it will get more lines as time goes by.
Dec 12, 2010 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
Have horizontal lines across the screen and some
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Jan 22, 2010 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Re: KDL-40S2000 black horizontal lines
If you have a horzontal black line (left to right) panel is bad.
Sep 04, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony KDL46BX450 - 46 inch 1080p LCD HDTV [KDL46BX450] Logo
55 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
