Question about Miele MVS2120OL Olympus S2120 Canister Vac
Need to open Miele s2120
Won't turn on
How to remove the bottom plate of Miele upright
you will need small star screw driver to do thsi once it i open be careful there are 2 little springs on the sides under the brush rller
Jun 21, 2014 | Miele S7210 Bagged Upright Vacuum
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
What type of vacuum bag does the Miele S2120 Olympus use?
www.vacuumworld.co.uk - you may find the bags you require on here - They have a great number of options for the Miele S Series
Mar 22, 2010 | Vacuums
How do I open the Turbobrush attachment on my Miele vacuum?
Loosen& remove 4 screws at bottomof turbo brush After cuttingventangledthreadvthrough crosswise with sissors. Turn turbo brush over gentlyon an even surface. Carefully separate and liftvoff upper casing. Then remove stuck threads.reassemble lift upper casingto bottom plateand pressinto place.turn unit over topside down and replace screws.
Jul 04, 2009 | Miele S251i Plus Bagged Canister Vacuum
Miele Solaris won't turn on after falling down 1 stair.
there is no reset on this model. look @ your miele info & it shows you where it would be. I just had to look for mine when it would'nt start. mine ended up being cord winder kink affecting motor.
good luck
linda
Mar 15, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Miele, model # S 514 does not turn on.
Sounds like the cable may be damaged. I think you're going to need professional repair... sorry can't be more help.
Feb 17, 2009 | Miele S514 Solaris Electro Plus Vacuum
Opening Miele S28i Vacuum cleaner
If it is similiar to the white star you may find the instructions here useful: http://www.sannerud.com/house/miele.html
hope so
Jan 10, 2009 | Miele S251i Plus Bagged Canister Vacuum
Ive got a miele revolution 5000 power plus and its just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=640910
Generic problem for all Vacuums
I’ve got a Miele revolution
Posted by rowler on Jun 02, 2008
I’ve got a Miele Revolution 5000 power plus and it’s just cut out the green power button on the handle is on but the orange button on the body does not come on it just flickers unless i open it up, any ideas?????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not familiar with the light system on the Miele Revolution 5000 Power Plus
But it has something to do with the electronic hose assm or the circuitry in the vacuum itself. I have listed the factory phone # listed below for your further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com/ Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Princeton, NJ 08540
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Vacuums
Miele Solaris Electro Plus will not turn on
I was using my Miele Solaris Turbo plus to **** the air off the Space Bag. Now I have the red indicator on and the vacuum cleaner won't turn on. Please help. This is my favorite vacuum cleaner!
May 17, 2008 | Miele S514 Solaris Electro Plus Vacuum
Miele MVS2120OL Olympus S2120 Canister Vac Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
