Question about Samsung HL-S7178W 71 in. HDTV Television
Check fan #2
Where is the fan located on the tv
Is there a manual for samsung dlp tv 5687- location of fan#2
http://www.manualslib.com/manual/510316/Samsung-Hl-S5687w.html
Oct 17, 2015 | Samsung Televison & Video
Samsung tv series sq01 has check fan 2 on screen then will shut off where is fan 2 located and what does this mean
you will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
Dec 09, 2014 | Samsung Televison & Video
#2 fan
you need to replace fan #2 , is located next to the lamp is a big fan compared to the other fan you can buy this fans from any electronics place
Nov 12, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
My tv comes on then says fan 2 error . were is the fan 2 so i can try to clean it and will it work if i do ?
Hello.
You can't clean fan, it is dead or almost dead it have to be replaced for the new one.
In order to determine which fan it is you have to remove TV's rear cover, locate lamp door switch ( it have blue plastic spring loaded lever) push it (otherwise TV will not turn on) and check which fan does not spin. Generally there are 3 fans - Ballast, lamp and DMD. DMD is the smallest one in size.
If you feel that this is too much to do - ask professional for help, repair should cost you around $200.
Regards.
Russ.
Dec 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
This TV is about 16 mpnths old. It has generated a message on the screen. "CHECK FAN NO 2". I can't find any mention in the user manual supplied with the TV
Inside the tv there are 2 fans for cooling the electronics power boards. One of them has failed.
Open the back of the tv , locate and replace it.
Oct 10, 2010 | Samsung LN46A650 46 in. LCD HDTV
E50a10 blinks four times
Four blinks is a fan rotation error code which means one of the four fans is not operating properly. Check these fans and replace any found defective.
  • Remove the lamp cover.
  • Remove the rear cover by removing the 13 screws holding it in place.
  • Check the fans.
053bd7d.jpgLocation of fans 1 and 2
Location of fans 3 and 4
Dec 07, 2009 | Televison & Video
My tv is telling me to check fan #2 could you tell me where it is located? and how to access it
Hi there! It is a bit difficult without a model, however the fans are located on the inside and fan 2 has failed so the panel will notify you of this failure. Depending on how many fans your panel uses check for the one that is either not turning anymore or is turning slower than normal. It may be marked as Fan 2 on the board where it is connected. Make sure that you purchase the same spec fan and take note of the direction of fitment for optimum cooling.(Direction of airflow or label side). Ensure that the power is unplugged from the wall when removing the cover or if not familiar please refer to a repairer. Best Wishes and Good Luck, JUS004
Sep 14, 2009 | Samsung Televison & Video
Fan number 2 in model hls5086w projection tv
the fan may be ok it may be another component thats caused the problem? if you have a meter check the fan you can also get intouch with the manufactuer they will try and help you
Mar 29, 2009 | Samsung HL-S5087W DLP TV
Samsung 50" DLP TV
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
Keep us posted.
Dan
Jun 27, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S7178W 71 in. HDTV Television Logo
21 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
