Question about Kettler GIRO GT Upright Stationary Exercise Fitness Bike
Kettle Giro GT indoor cycle seems to have a hitch or catch during the revolution when the pedal hits bottom. What can be done to fix this. We just finished assembling the bike. The problem is even mor
The revolution should be smooth without catches.
I have a Marcy Revolution indoors spinner bike. The right crank arm where the foot pedal screw into is stripped. Can this be fixed and what do I need to fix it
Yes it can be fixed, This is usually completed by a bike shop. ITs a complex operation, usually requiring special tools, grease and ball bearings. Contact your nearest bike shop
Oct 10, 2014 | Cycling
Recently assembled and tried bike. There seems to be a catch/hitch in the rotation when pedal at bottom. It should be smooth. What could be wrong and how to fix?
It's probably the bottom bracket bearing. Exercise bikes typically have really, really cheap bearings in them. I have the same problem on my Horizon M4 with a lot of bearing chatter when doing standing high resistance.
Mar 22, 2014 | Kettler Giro GT Programmable Cycling...
Power Supply
Try emailing the parts department at Kettler USA: Kettler USA online shopping for tricycles pedal tractors ellipticals...
I used to have to contact them when I repaired Kettlers at the bike shop.
Feb 25, 2014 | Kettler Ergo Racer GT Indoor Cycling Bike
Power cord overheats
The thermostat is not shutting the unit down and cycling it on/off as it should. This will cause the power cord to overheat and it will catch fire. STOP using this unit and either replace it or have it repaired. More than likely cheaper to just replace it.
May 30, 2010 | Krups FLF2 Cordless Electric Kettle
Servicing
Locate where the noise is coming from, chances are the bearings have gone bad go to Kettler fitness.com they have contact info on their web site.
May 16, 2010 | Kettler Ergo Racer GT Indoor Cycling Bike
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Water dripping of Steam Wand during brew cycle
If water is dripping out of steamwand then the valve assembly is not working properly and needs to be replaced.
Aug 17, 2009 | Saeco Odea-Giro Espresso Machine
Kettler GIRO GT Upright Stationary Exercise Fitness Bike Logo
55 people viewed this question
Top Kettler Cycling Experts
dante
Donald Ayers-Marsh
Vern Reece
Vern Reece
Level 1 Expert
Are you a Kettler Cycling Expert? Answer questions, earn points and help others
