Question about Eureka Bravo II Bagged Upright Vacuum
Filter locations where are the filters (3) located
How many filters in the DC25 dyson vacuum cleaner
Hi Cheryl, it's Jack at Dyson.
DC25 has two filters, engineered to last the lifetime of the machine in normal use. One is housed within the cyclone pack, and one within the ball shell. We recommend washing these at least once every 3 months, using cold water without detergent. Allow both filters to dry completely before replacing them - this may take at least 24 hours.
Our video guide below will show you where both filters are located, and how to wash them correctly:
If you're concerned your DC25 isn't picking up as well as it should be, washing both of the filters as shown should definitely help. However if you're still concerned after washing and replacing the filters there may be a blockage somewhere. Our online Support pages should help you locate and remove any obstructions: http://www.dyson.com/support/dc25/dc25-multi-floor/diagnosis-root-menu/dc25filterwashvid/dc25filterwashvid/performance-flo-dc24-suction-check
If you'd prefer to speak to our experts directly for assistance, you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 19, 2015 | Dyson DC25 All Floors Bagless Upright...
Why won't My Hoover savvy won't turn on
Hi Denell! Your vacuum has a thermal protector that will shut it off automatically if it becomes overheated. This is usually caused by a clog or a filter that needs to be cleaned or replaced. Follow these quick steps to check your vacuum for clogs.
1. Remove the dirt cup and the dirt cup lid.
2. Grasp pre-filter frame and pull up and out of dirt cup.
3. Separate the pre-filter and Hepa cartridge filter. The pre-filter can be cleaned with a brush and then rinsed with water. Allow 24 hours to air dry.
4. Clean the Hepa cartridge filter by tapping either of the ends until dirt stops falling from the filter. The Hepa filter should be replaced once a year.
5. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
6. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose
The vacuum will turn back on after it cools off. This can take up to an hour. If the vacuum has been off for over 24 hours we recommend taking your vacuum in to a service center for repair. Follow the link to locate the nearest authorized service center to you.
Service Center Locator
Hope this helps!
Aug 13, 2014 | Hoover U8145-900 Savvy Bagless Upright...
How do i fix a bissel not sucking
Clean the filters. Check your User's Guide for filter locations. Or, Clean the Water Tank Filter located on the tank Cap. Clean the Flow Indicator Filter Located Under the Flow Indicator. Hope that Helped.
Jul 23, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Why won't my hoover u6434 900 turn on?
Hello! The vacuum has a thermal protector sensor that will automatically shut off the vacuum when it is overheated. The vacuum should turn back on once it has cooled down. This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are steps you may follow to check your vacuum for blockages.
1. Locate the primary filter behind the side grille. Wash the filter, squeeze it out and allow 24 hours to air dry outside of the vacuum. It should be washed about every other month.
2. Locate the secondary filter located in the vacuum base under the paper bag. The secondary filter can be washed in the same manner as the primary filter.
3. Replace the bag if it is full.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brush-roll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Hope this helps!
Jun 14, 2014 | Hoover U6434-900 Bagged Upright Vacuum
How do I clean and with what,a Hoover elite lifetime hepa filter?
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1. Press on the tab located on the side of the filter cover to remove.
2. Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
Jun 09, 2014 | Hoover U5507900 Elite Rewind Bagless...
How to Troubleshoot hover and tunnel U6476
Hi! Below are step-by-step instructions for trouble-shooting your Hoover U6476.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
May 31, 2014 | Hoover U6476-900 WindTunnel Vacuum
Where is the filter
Dyson put filters in three locations. 1) Remove the canister, there should be a release clip in the front above the handle, this allows the top to tip backwards. 2) On the left side, at the main unit is a round cover with thumb release, this pulls straight out. These are cleanable filters, RINSE ONLY no soap!!
3) Under the canister is a filter, the cover has 3 clips which need to be pried gently to open the cover. This is a hepa filter and cannot be cleaned, it must be replaced.
Nov 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-parts-schematic.pdf
Also, here's the link to the owners manual for your model as well:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-owners-manual.pdf
I hope this helps you,
Chris J.
GoVacuum
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
No suction
Your filters are clogged. Dysons have two filters. One is the washable one located directly beneathe the cannister. The other is a post filter located inside of the vacuum housing. This filter should be replaced by a Dyson technician. The Dyson company recommends you replace your filters every 6 months to a year, depending on how often you vacuum.
Sep 09, 2009 | Dyson DC14 All floors Bagless Upright...
I have a dyson alergy machine, I have emptied it, but I would like to clean the filter. I can't locate where the filter is or how to get to it to clean it. The manuel for this is not with the machine. ...
Greetings Irlawren3,
It all depends on the model you currently have. The filters on some are above the motor and some are on the side housing. Its pretty clear looking at the unit where the filters are located. I would suggest investigating your unit and looking for the filter.
When you do locate the filter, it is to be washed with plain water and allowed to dry for at least 12 hours before being put back into the unit.
One thing that helps determine the model is the color also. What color is it?
Thanks!
Dorothy
Go Ahead. Use Us.
Jul 30, 2008 | Vacuums
Eureka Bravo II Bagged Upright Vacuum Logo
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
