Question about Maytag Microwave Ovens
Clock digital numbers are all screwed up
The numbers all look alike. the three looks like a five and a two looks like a three how can this be fixed
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
Oven does not turn off when the door is opened.
Check the door latches. If one is broken and stuck in, the microwave will not switch off when being used failing that call a microwave repair service.
Apr 22, 2017 | Whirlpool Microwave Ovens
How to set the digital clock pls
Without your model number this is a GENERIC answer that is applicable to MOST microwave ovens.
1. Press Stop//Pause
2. Press Clock
3. Set Time
4. Press Clock
Time is now set and the Microwave is ready for use.
If this does not work.. I need you to respond with your model number to look up your exact steps.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Microwave Ovens
How to set clock?
You can set the clock to a 12 or 24 hour system.
For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
Mar 05, 2011 | Emerson MW8107WA Microwave Oven
Setting the clock it doesn't make sense tried # of times won't program can do 4 ditget but can't do 3 ditget
Time is 4 digits. 05.32 is five 32
All appliances require four digits whether 12 or 24 hour clocks.
Jan 09, 2011 | Magic Chef MCD1611ST Microwave Oven
How to set clock on asda microwave, p80d20al t5
1. Touch CLOCK pad.
2. Touch CANCEL pad.
3. Use number pads to enter the correct time. You need at least three numbers to set time. (Note that the clock is a 12hr format clock)
4. Touch CLOCK pad again.
Aug 31, 2010 | Microwave Ovens
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Setting clock
In most brands, you set the clock by one of these combinations of key presses:
Apr 22, 2008 | Microwave Ovens
Microwave Ovens Logo
13 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
