Question about Miele W4840 Front Load Washer
Display screen shows nothing
Washer works but sreens display shows nothing
My Touch sreen IQ 770 PC completely black out ... Windows not showing .How I solve the problem ? Thks
You need to determin if the display is defective or the video card.
Connect a know working display to your PC and if you are able to view the display, your video card is fine and the display must be defective.
Try connecting the display to another PC and see if it works, if not your display is defective.
I hope this helps.
Good luck and have a great day.
May 18, 2011 | HP TouchSmart IQ770 PC Desktop
My sreen is showing upside down how can i fix this problem?
HI, when a screen starts showing upside down display,that means the flex of the phone is getting damaged.
The flex is a thread like object that connect the phone board to the screen display area.
The flex of the phone allows the phone to display of the phone.
To be able to correct the display problem,you will need to replace the flex of the phone.
Phone is a little bit technical to handle,i would advice you contact a skilled phone repair manin any phone repair store around your area for assistance..
Hope that helped.
Thanks for using fixya...
Jan 21, 2011 | LG Rumor 2 Cell Phone
The display screen is showing CL. Nothing is
CL is child lock. See your users manual for unlocking the child lock procedure. Usually it involves pressing 1 or 2 buttons for 3 to 5 seconds. Many machines actually have a lock button you press for 3 - 5 seonds. Others use the stop pause button.
Kelly
Aug 30, 2010 | LG WD-1280FHD Front Load Washer
My phone turns on but nothing comes up on the screen at all, its just black, i can still do things like get into the music so the phone is still working, but the sreen (display) is just black, i think i...
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 04, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Nuvi 350 Color does not show properly
Most likely the LCD needs replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 20, 2010 | Garmin Nuvi 350 Car GPS Receiver
Vaio tr1a sreen not working
You need to check if the issue is with the LCD or with the video card. Please try to connect the laptop to a different monitor or another display device. If you get display or any images then you need to get the lcd replaced otherwise its a video card issue.
Jun 20, 2009 | Sony VAIO TR1A Notebook
Swap nintendo ds screens
No the top is just display while the bottom is a touch screen. Two types of screens physically impossible to switch.
Mar 15, 2009 | Nintendo DS Console
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
Computer problem
may be u have problem with the display driver or u have a corrupted windows xp try to run the windows in "ENABLE VGA MODE" if it works fine then just reset the display settings else u have to try to repair / reinstall winxp
mai me ur response @ vishwas_4u@rediffmail.com
May 01, 2008 | Compaq Evo N610C Notebook
Display problem
could be 2 main causes, either the LCD converter under or behind the screen under the beizel has failed and is messing up the display, or simply the sreen could have been cracked at one point, either way these parts have to be obtained from toshiba.. EMPR do toshibas spare parts, if you are in australia
www.tosh.empr.com.au
Dec 10, 2007 | Toshiba Qosmio G35-AV600 Notebook
Miele W4840 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
