Question about SanDisk Sansa e260 MP3 Player
Well, i plug it in for it to charge and it will charge for 1-3 min and then the screen sorta goes a bit darker and the blue wheel will turn off and that's it really won't charge.
    Problem Solver:
  • 16 Answers
Get a new charger because your charger is probaly not working right and if its not working send it in.
Posted on Jun 14, 2009
Dp42840turns on then turns itself off
Hello, if it stays on a few seconds and goes off it may have a backlit issue, and unfortunately a lot of times it's the florescent tubes in the display panel that are bad, and it's usually the ones about 3 or 5 inches from the top. Put the tv on an off channel to where you get a blue screen and look to see if it looks like a little bit darker across the screen there. let me know or take a picture while it's on so I can see it....tks
Sep 17, 2014 | Televison & Video
1. picture is getting darker 2. there is a green outline when the brightness is turned up
Hello ksolovy, i understood your Problem with the Sony KP-53V90 53 in. Rear Projection Television,In fact i encountered already that kind of problem you have it now. Check first the color wheel im sure that the blue section of your color wheel was burned and the blue color turn to dark; That's why you have seen dark picture, Re-place color wheel.
Dec 21, 2010 | Sony KP-53V90 53" Rear Projection...
Blue d52wlcd
The other stuff is probably the Engine as well. Before going any further, have them replace it again and see if the other problems show up. I am willing to bet they wont. These Engines are mostly refurbished units and if they originally had intermittent problems on the Digital Board that comes mounted on the Engine it would get passed on to you.
I would not wait before having it replaced and I would Call LG first to let them know you got a dud replacement Engine. Let me know how it comes out.
Skyassoc
Aug 29, 2009 | Zenith D52WLCD 52" Rear Projection...
Sumsung 930b goes dim,and flickers after about 3 min.
This sounds like the inverter has gone bad. If the bulb were bad only, you would see a faint image on the screen with a flashlight.
The problem is on this monitor, it will probably cost about $100 or so to take it to a shop to get it fixed, and that is nearing the cost of a new monitor.
If you are a little bit handy, and can disassemble the monitor, you can replace the inverter. The hardest thing about this, is getting the monitor faceplate open. Just use something firm and softer, such as a nylon spudger (this is something you can find online) or you can carefully use a thin scredriver. You just have to be careful, those cases are really tight.
Here is a good guide for general ideas on how it is done.
http://www.instructables.com/id/Replace-LCD-Backlight-Inverter-on-Any-Monitor-for-/
Paul
Apr 09, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Picture gets darker
Apparently there is a loose connection somewhere. Please have unit checked out by a pro tech
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Moto q want trun on
Try taking the batteries out ( fully disconnecting them from the gold contact points) ... then put them back in with the charger already plugged in. It should go to that blue charge screen instead of turning on. LEAVE IT ON THAT CHARGING SCREEN for at least 5-10 mins. Now, Hold down power, screen goes black... then tap power about 2 seconds after screen goes out, and it should start up as normal. If taking the battery out has no effect, I would investigate whether that (the battery... being dead/unchargeable) is the problem. I'm hoping one of the two answers gets ya where you need to go.
OH AND YOU CANNOT USE USB CHARGER TO DO THIS. IT HAS TO HAVE DIRECT FROM-THE-SOCKET POWER TO CHARGE UP THAT FIRST BIT OF COMPLETELY TAPPED CHEMICAL (ELECTRICAL) REACTIONS.
Jul 31, 2008 | Motorola Mobility Moto Q
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
SanDisk Sansa e260 MP3 Player Logo
51 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
