Question about Dynojet Jet Kit - Suzuki GS500E 89-00
Idles rough and holds rpms
Idles rough, holds rpms, doesnt go up past 7000 rpm
Rough idling 2000 carbureted heritage classic
It sounds as if you may have some partially contaminated fuel entering the carbs. About the only other thing I can imagine that would cause this is a very small vacuum leak at the point where the carbs mount. Carbs have even been known to shake loose at the air horn to main body gasket. Good luck!
Oct 18, 2014 | 2000 Harley Davidson FLSTC Heritage...
Rough idling when warm heritage
Sounds like it is sucking in air from somewhere. Check between carbs or other gaskets. Good Luck
Low MPH/RPM issue
Autozone will read the computer codes for free. Many other auto parts place also provide this service. You need to know the car's OBD codes to start fixing the problem.
Jan 02, 2014 | 2001 Mitsubishi Eclipse Spyder GS
Hard to start, dies, missing out, hesitation, low rpm take off missing out
Fuel filter clogged, weak or faulty fuel pump. Have fuel pressure checked, if its ok, then check igniton coil or module.
Dec 13, 2013 | 2000 Chevrolet Silverado 1500
Why does my 1997 chevy s10 have a high idle while coasting?
Sounds like a dirty air filter is putting the mass airflow sensor out of range. The throttle position sensor is subject to physical wear, the age of your truck warrants replacing it. The coolant temp sensor controls the Idle Air Solenoid which determines idle speed ( cold, high idle, 1200 rpms open loop mode for the ECU) and (hot, low idle, 800 rpms, closed loop mode for the ECU) If the truck does not have a Mass airflow sensor, check the Manifold absolute pressure sensor (MAP). Perform an OBDII scan for stored fault history to avoid buying parts you don't need. Do the cheapest fixes first. Go ahead and change the fuel filter also. There is a lot of water in todays fuels
May 29, 2017 | Chevrolet S 10 Cars & Trucks
Idle is very rough. drives but doesnt make power. wont pull past 3000 rpms
are all the cylinders firing.
is the fuel filter blocked.
is the air filter blocked.
is there black smoke coming out the exhaust.
Mar 22, 2011 | BMW 6 Series Cars & Trucks
05 Bandit 1200S idles low, run rough at low rpms,
Try buying new diaframs for your carbs, because of the diafram and piston operation, if the diafram becomes weak due to heat from your engine, and by the diafram not beeing rigid enough, it hesitates to lift the needle out of the jet causing the lack of fuel at low tack/rpm when throttling up or accelerating slowly.
Jun 11, 2010 | 1997 Suzuki GSF 1200 Bandit S
I have a 1992 camaro at idle its ok . In gear low rpm rough runin
I worked on one of these the other day and what fixed the same problem it sounds like is I changed out the distributor cap and rotor. the rotor can be a pain to get off. and also don't cross any plug wires take one off at a time and put it on the new one.
Jul 06, 2009 | 1992 Chevrolet Camaro
2003 toyota matrix xrs will not rev beyond 7000 rpm and ldles rough
Rough idle = tune up
There is a rev limiter on the Matrix set at 6500-7000 rpm
Jul 18, 2008 | 2005 Toyota Matrix
Dynojet Jet Kit - Suzuki GS500E 89-00 Logo
479 people viewed this question
Top Dynojet Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Dynojet Garden Expert? Answer questions, earn points and help others
