Question about Health-O-Meter Bathroom Dial Scale with Counselor, by Health O Meter, Model: C47 01
How to fix sunbeam
Dial scale
When i plug in my sunbeam humidifier I get an er on the screen what should i do
Impossible to know without communicating with Sunbeam. "ER, ERR" and the like are normal failure mode displays whenever the unit can not operate as normal. As there are electronic components involved, a failure of any one will fault the unit.
And it could also be something as trivial as a buildup of scale on the water sensors. (Have you tried a thorough cleaning of the unit?) I would first try soaking the water chamber in white vinegar for several hours.
It that does not fix it, it's probably done for.
Jan 03, 2016 | Sunbeam SCM631-UM Cool Mist Tower...
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
Healthometer change kg to lbs
With scales off. Hold select button for approximately 5 seconds, lbs flashes hit select to confirm
Apr 28, 2012 | Sunbeam Healthometer Body Fat and Weight...
I have a Sunbeam Mixmaster 2351 Heritage Series that the speed dial control numbers fade. Sunbeam replaced my mixer but want to prevent the same problem for reoccurring, Any suggestions?
I would propose to solution to your problem,
one. Try getting some clear contact and cutting a a square or circle a little more than the size of the dial. Removed the dial if possible and later clear contact over the surface.
Two. Get some clear nail polish and cover the markings on the dial with thin coat.
Warning warning warning!!! (Test the nail polish on a surface that is not exposed, for example underneath) to make sure that the nail polish does not react with the surface of the mixer.
Regards
Trevor
Feb 15, 2012 | Sunbeam 2346 Heritage MixMaster Series...
I am trying to locate an Owners Manual for my Sunbeam Controled Heat Sauce Pan model SP 5. Works fine as deep fryer but would like to know what else it can do.
I tried looking for the Sunbeam "SP 5" and came up with a digital scale. A web search for "Controlled Heat Sauce Pan" turned up a paper cookbook How to Get the Most out of your Sunbeam Controlled Heat Sauce Pan for sale for $9.95 (go to item 15 on the page).
Jan 05, 2011 | Sunbeam Crock Pots & Slow Cookers
Recently when I step on the scale I get and E
Try stepping off when you get the E and step back on after 5-10 seconds and see if it works.
Aug 12, 2010 | Sunbeam Healthometer Body Fat and Weight...
I have a Sunbeam digital scale and Model SDR520CO-01 We just recently moved. But somehow it doesn't work any more. Rarely we can get it work but very very slow and show strange pattern of showing letter E...
Incase anyone has this issue this is simply a case of not using the scale correctly.
You must first tap the bottom right corner of the scale for around half a second with pressure with your foot and then remove your foot. When the blinking has gone to 0.0 you may then step on the scale.
If you do not tap the scale and then wait for the 0.0 reading you will get an error reading. This was actually on a sticker on the product but I imagine some people remove it after purchase etc etc.
Jul 03, 2010 | Sunbeam Digital Scale HDL205KD01 ()
How do i reset each individual person
mcdevito75 here, There should be a button or knob close to the indicator you can press, turn, to return scale to zero for each person.
Jun 26, 2010 | Sunbeam Healthometer Body Fat and Weight...
Scale build up problem in iron
White vinegar and a toothbrush. You can clean the whole steam path with 25% vinegar to 75% water. Steam it through. Run plain water afterwards to rinse it out.
Feb 06, 2009 | Sunbeam Irons
Health-O-Meter Bathroom Dial Scale with Counselor, by Health O Meter, Model: C47 01 Logo
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
Shehu Pro
Shehu Pro
Red721
Level 1 Expert
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
