Question about Haier NuCool 2.8 cu ft Compact Refrigerator Virtual Steel C-RNU281VS
Smoking All of a sudden my refrigerator started smoking
Why when I couldn't start my toro 6.5 gts lawn mower with tecumsuh engine,I sprayed carb cleaner into carb and it started but smoked and knocked. what caused this problem?
bob if you spray carb cleaner in and it started that is a sign of not getting fuel. but if it is smoking and knocking you have a bad outlook for that engine. did you hit anything with the blades while mowing that caused it to stop suddenly? did you tip it on its side as the oil may have run in the carburetor. that can cause the smoking. does it have to much oil in it?
Apr 28, 2016 | Toro Garden
Just replaced valve covers on Nissan Maxima 2002 due to misfire. Now it smokes and burns oil every start? What's should I do .
If is is only smoking when you first start it up. Most likely the valve guide seals, oil is leaking into the cylinders and smoking when you start it up.
Mar 20, 2016 | 2002 Nissan Maxima
White Smoke when i put gas in car
The most common cause of blue (or worse still) being expelled through the exhaust system is extreme wear in the engine, or, if you're extremely fortunate a significant OVERFILL of the engine oil level. One other possible, though unlikely cause, is a fault in the engine's scavenging system.
Has this problem occurred suddenly without warning? Had the car been serviced immediately before this event, or the engine oil topped up?
Jun 06, 2012 | BMW 525i Cars & Trucks
516 Cdi sprinter sudden blue smoking for few minutes and after OK
somthing in the ignition is causing a weak spark--or fuel inject circuit is running to rich----------all causes improper burning---------get a computer diagnostic done
Apr 07, 2012 | Cars & Trucks
I have a 2009 POLARIS RANGER 500 with 64 hours it
if its a black smoke its running rich. check your air filter and air tube for clogs. something may have made a nest in there.
Nov 21, 2017 | Polaris ATV
My ford escort 1998, started smoking badly from
Hi:
If the smoke is whitish in color, and just started doing this suddenly, then most likely you have a leaking head gasket, and it is letting coolant get in your cylinder, and possibly oil into your coolant. I am not sure about the noises you are hearing, but you should have your car checked out as soon as possible, or your engine could be permanently damaged, or it could be already.
Jan 18, 2010 | 1998 Ford Escort
Smokes in the rear
well that isn't good. I would not use it. I would check to see if your warrantee is up(check with the store you bought it at and the manufacture----some stores have warrantees that are different than the manufactures) . also check the manufactures website for recalls on your tv. If that don't work you can take it to a electronics repair shop to fix it. But it may be cheaper just to buy a new one.
Hope this helps
Aug 09, 2009 | Polaroid Televison & Video
Started smoking and fan is still running but not cooling. neither
You have a bad compressor that is the only thing that will make something smoke and not let anything stay cool
Feb 08, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Haier NuCool 2.8 cu ft Compact Refrigerator Virtual Steel C-RNU281VS Logo
14 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
