Question about Garden
Need to lft tractor cab on 6420 ,line leaking
See oil leak can not get to because of the cab
  • Garden Master
  • 2,478 Answers
Some tractor have jacks to jack up the cab.
Posted on Apr 29, 2014
2 Suggested Answers
  • 95 Answers
SOURCE: Husqvarna YTH2448 engine leaking oil
That sounds like the sump gasket is leaking, sometimes the briggs machining at the sump and head areas are a little rough and a bad fit can allow the gasket to blow,if it is leaking it is actually sucking air in rather than pushing oil out while it is running. You would have to drain oil, remove the engine turn it upside down,remove the oil pump cover plate( 3 small screws) pull oil pump rotor and drive shaft out,remove sump bolts,replace gasket and reassemble.Be sure to use a light coat of gasket sealer like black silicone.
Posted on Jul 30, 2009
Getting oil in the water
if you are getting oil in the water but no water in the oil the cooler inside the radiator is leaking. If the oil has redish to brown color it is the trans oil cooler leaking
Mar 27, 2014 | 1997 Dodge Ram 1500 Club Cab
Oil leak when ran hard fills cab with smoke
Are you sure you don't have an oil leak? And have you had the oil changed or using the right type of oil?
Mar 18, 2010 | Chevrolet Chevy Cars & Trucks
Engine leaking oil. what is the solution ?
yes you will smell it in the cab,ask a local mechanic to have a look at the oil leak ,cant advise where it is or anything because i do not have my head under the bonnet
Jan 11, 2010 | 1999 Nissan Sentra
I have a 2003 f250 6.0. big oil leak
Either the rear intake gasket is leaking,or the oil sending unit.It sounds more like a oil sending unit.It will have one wire going to it.It will most likely have oil all over it,and around it.With the amount of oil you are talking 275877.jpg,it would almost have to 833439.jpg the problem.It would look similar to these.Please let us know if this helps.thank you.
Oct 25, 2009 | 2003 Ford F250 Super Duty Crew Cab
Driving home from work I started to smell and see smoke in cab
If you have recently changed or had the oil changed I would suspect a bad filter or the old oil filter gasket still on the filter boss and a new filter with an additional gasket installed on top of the old gasket. Usually in a short time the old filter gasket will blow out causing a massive oil leak. To locate the leak fill the engine back to the full mark with oil and start it and look for the leak.
Oct 25, 2009 | 2001 Ford F250 Super Duty Super Cab
Oil leaking from the turbo on my 1999 ford f-350 7.3 liter powerstroke. leaking on the intake there is a puddle
A little bit of oil is normal, but if oil is dripping all the time, the turbo needs to be repaired.
Regards
Phillip
Sep 18, 2009 | 1999 Ford F350 Regular Cab
Oil passing into cooling system
I would assume the truck is an automatic. If the oil is red in color or pink in the radiator then you may hae an oil cooler leak. The auto tranny cools the oil by passing the oil through the radiator in tubes. If these tubes are leaking you would experience the oil leaking in to the radiator. The other worse scenario would be that you have a cracked cylinder wall that is leaking motor oil in to the crankcase. Good luck
Mar 15, 2009 | 1994 Ford F350 Crew Cab
I have an issue with my 94 ford 350 diesel. A major oil leak
hello if it leaks in alot of places you may want to check your pvc valve
Feb 16, 2009 | 1994 Ford F350 Crew Cab
Oil smell in cab
Get under there and look to see where oil is escaping. Oil, like everything else runs downward. Therefore it may be coming from the top of the engine. If you have a 4.0, the valve covers are plastic and tend to leak a bit... Generally you can gently (or you will break them off) tighten the v/c fasteners and eliminate most if not all of the seepage. If it continues, replace the gasket. There is only one seal between trans and engine, called a rear main seal. It is better left alone. It's a big job and best done by a shop.
Dec 30, 2008 | 1999 Jeep Grand Cherokee
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
