Question about Garden
Service Lights I own a Mitsubishi MX55 excavator. The CPU light is blinking and #51 service light is always on. Can anyone tell me what these lights mean and what the problem may be so I may fix it.
  • 235 Answers
51 usually means the 250 hr service is overdue .
CPU blinks in a code - is it steady or a sequence ?
Posted on Jan 02, 2010
When I switch on my jcb js 130 excavator the eighteen warning indicator lights are not going off
How to reset the service light on a JCB JS 130 Excavator ...
www.fixya.com/.../t1428872-reset_service_light_jcb_js_130_excavator
Dec 25, 2008 - how to reset the service light on a JCB JS 130 Excavator Hi I have serviced our JCB JS 130 ... my self and I am woundering if there is away of switching off the service warning light ... Helpful 41; Not Helpful; 1 Comment; Flag ... Posted on Feb 18, 2009 ... What kind of brake fluid goes into a jcb 3cx 1985/86?
Oct 29, 2015 | Cars & Trucks
My check engine light and vsc trac and off lights have come on ... I have been told its the camshaft position sensor ... Can anyone confirm ???
The engine light is telling you that the CPU has found
sensor/s outside set parameters during the checking process. Have the fault codes read before wasting time and money guessing what has failed. Replace with
genuine items only as aftermarket units are not always compatible with the
settings in the CPU.
May 05, 2013 | Cars & Trucks
What does diagnostic lights mean in dell studio 1535? How do I understand what the problem is by looking at the flashing lights? For instance, what is the problem if mute and volume up lights are blinking...
I have seen questions about the diagnostic codes (volume/mute LEDs) on Dell Studio 1735 1737 laptops where the Mute and Volume up lights stay on while the Volume down Blinks. So far as I can tell, by searching the web, no one has posted the meaning of these lights.
Well here is a link to tell what the light codes mean. If your system has power but is not performing a POST just check if the mute, volume up, and volume down multimedia buttons are lit in a sequence indicating a system problem.
Here is the wesite to explain those POST failure codes.......
http://www.techmonsters.com/DellTraining/bin/Foundation2010/Portables_Foundation_2010/Studio/Studio_1737/1737/general_ts.htm
Dec 08, 2011 | Dell Computers & Internet
I own a Mitsubishi MX55 mini-excavator. The electronic boom controls aren't working. the 'CPU' lights blinks continuously Code 51 or 5P is lit on the cpu display. Anybody has the...
For anyone having this problem I had it too and solved it. First off follow the wires down from the safety lever switch "located halfway down your left joystick tower" you need to pull the floor plate off to expose the valves and wires. Unplug the safety switch and you can bypass the switch with a 1 inch piece of wire to see if that eliminates the SL CODE. that stands for safety lever. It's not safe to leave the wire there even though I did. Your levers will be live all the time if you do... I'm fine with that for my machine. Now if you have a code 51 and a cpu light flashing what I did to fix mine was pull the cover off the cpu, its a big computer chip. I unplugged my plugs and put a little bit of electrical Grease non conductive on each one and plugged them back in. the plug that I was having problems with was the very bottom one and it's one of the biggest plugs. right above that there is four lights, they are green. when you turn the key on those lights should blink in sequence starting from right to left followed by a click noise. I noticed that when I was getting my code 51 those lights were just flashing intermittently and not going in sequence and there was no click and the code would come up. When I first realized that it was the plug and I pushed it back in and I got the CPU to stop flashing and the green lights would go in sequence followed by quick click I put the panel back on but I found that the panel was pushing on the wires just enough to make the plug not go in correctly or maybe one of the wires was being pushed on enough that it wasn't making contact. So I ran the wires a different way in the Box I flip them around into a different Loop and that seemed to do the trick along with the grease on the plug I haven't had a problem since I hope this helps you I spent hours online trying to find something that would have said this so I thought I better put it on there for the next guy my email is timberwolf_skidsteer@hotmail.com if you have more problems I may be able to help
Jun 27, 2011 | Garden
Blinking lights, not washing
Usually blinking lights are indicating bad touch panel buttons. Remove kick plate, (black panel under door) and find service instructions there. It will tell you how to test button panel, as well as any codes flashing. Also will tell you hot to try a reset.
Jul 21, 2010 | KitchenAid Dishwashers
Blinking green light
Contact a Mitsubishi service center and tell them the count of the pattern of flashes of the green light (Usually 2 - 9 flashes, a pause and then repeats) It will not be user serviceable.
Mar 30, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WD-62525 I have the flashing green light problem. Unplugged the power srtip this morning, When I got home tonight plugged it back in and the green light flashes 12 times, pauses then flashes 12...
there are many capacitors that leak on this set and chances are that some of them were missed. Sorry you spent so much money on that repair but Mitsubishi service could have fixed it right for $300.00 because they know where all of the caps are and they burn it it for several days before it leave the service center.
Jan 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Picture blinks then gets lighter then darker
Good Day, freden899;
Your 2000 unit may be experiencing fluid on the PCB's (printed circuit boards). Does the pic blank or flicker?
In either case I would say your TV is sick and that you need to see an Authorized Service Center DR. Always ask for an estimate before any repairs are performed.
Good Luck, big IRISH.
Aug 14, 2008 | Mitsubishi WS-55807 TV
Sony kp 51 ws 500
· 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Hopefully, the descriptions of the blinking lights and the symptoms and problems will point you in the right direction to tell the problem with you Sony Projection Screen Television. If it is not enough, do not worry -- in the coming few posts I will talk about entering the Diagnosis and Service modes for your television set!
Feb 15, 2008 | Sony KP-51WS500 51" Rear Projection...
Garden Logo
280 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
