Question about Radio Communications
Repair tv ears
Where can I send the headsets to repair bow arms which cracked close to the base of the headsets.
Repair crack in headset for tv ear headset
probably is but if it doesn't work you can blame only yourself
Mar 18, 2015 | Radio Communications
I have a constant beeping on my jabra headset gn 9350
headset not syn'd with base, replace headset in base and remove power from base
count to 10 re-power base allow set up to complete, green lights across base and blue battery light on ear piece, allow to charge if less than two green lights on base.
if this still does not work slide ear piece apart count to 3 and silde back together again replace in base and allow to light up again, it will now work
Jul 18, 2014 | Jabra GN9350e Wireless Headset
Does not drown out background noise, only makes it louder
If you have just bought these, take them or send them back.
Feb 02, 2014 | Dual TV Ears - Headset System Headset
TV Ears -Light is green on base.Rest of lights are not on..Cannot hear sound emanating from earphones
When you have your head phone on your ears, there should be no Green light, unless you have another headset on the transmitter base in Front Slot.
Having Green or Orange light on the larger LED on the left side has nothing to do with the audio, that light is only for Charging indicator.
You should have ALL FIVE RED LED light on, if any one is out, you have a failed LED and would need to replace ALL small LED ( five of them on the right side) with LEDs from Radio Shack SKU# 276-143 High-Output Infrared LED or buy it from http://www.newark.com/optek-technology/op291a/ir-emitter-890nm-t-1-3-4-through/dp/08F2980.
Aug 24, 2011 | Dual TV Ears - Headset System Headset
Ear peice wont charge from the charging dock
If it is under warranty (1 year) Plantronics will replace the headset and charging base case for you. Package up both the headset and the charging case and include your return address, phone number and a copy of your receipt and send to:
Plantronics ATTN: Service Center 345 Encinal Street Santa Cruz, CA 95060
Good luck from Headsets Direct - 800-914-7996.
Aug 24, 2011 | Plantronics Discovery 975 (8164001 P)...
When I plug in in my plantronics 367 closed ear gaming headset all I hear is the sound I cant get the mic working
This is a plug-n-play headset, so no special software is necessary for it to work properly. You want to make sure the leads are plugged into the right jacks on the computer and that the jacks are live.
Good luck from Headsets Direct!
Apr 18, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
Right ear arm broken on tv ears.
http://comfortabletvearsconversionservice.yolasite.com/
Mar 16, 2011 | Radio Communications
Broke the ear hook for the Motorola h500 bluetooth headset
They do not make earhooks alone. You must send it back and they will replace the whole unit.
May 12, 2008 | Motorola Mobility H700 Headset
Jabra ear piece
Call the Jabra Support hot line they will send you replacement earhooks free
Takes less then 5 mins to get them sent
Sep 30, 2007 | Jabra Bluetooth Headset with Adjustable...
Radio Communications Logo
14 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
