Question about Mtd Arnold Corp RearMounted Bagger for MTD and YardMan Riding Mowers For 20
Lawn man idles too fast
Is idle arm missing spring. It either idles too fast or two slow and won't stay in the middle.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 140 Answers
Could be a broken or worn throttle shaft,letting air in to the carb when it shouldn't !
Posted on Jan 07, 2015
Greetings. I have a eu2000 honda inverter with the following problem. The high generator runs too fast, when the idle is activated, slows down a bit, but does not increase
on the governor control back to the carby , there is a screw that adjusts the spring tension for the governor arm
that screw is the adjustment for engine operating rpm not the idle screw
Dec 05, 2016 | Honda Electrical Supplies
How do I adjust the idle to slow?
check for bends in linkage or missing springs
any air leaks will increase idle
Sep 11, 2015 | Garden
Honda Civic the idle on car idles up and down manly when stopped
When an engine just idles fast and slow, it's usually a vacuum leak somewhere. You can spray on the hoses carrying engine vacuum to see the leak.
Hope this helps.
Mar 25, 2015 | Honda Civic Cars & Trucks
Idle speed adjustment
You could also have an overused spring on the carb the connects to the govenor arm. Take the spring off and see how worn out it is.
Nov 06, 2013 | Toro Lawn Mower With Toro Power Tools
Engine will not idle. runs very fast. will not run slow.
Don't leave the engine running that way - it can be quickly damaged. There is a "governor" that is designed to keep the engine from running too fast. Take off the hood, find the carburetor and look for the throttle lever attached to it. One end of the lever will be attached to a cable that is pulled by your hand throttle. The other end is supposed to have a spring attached and that goes to the governor. If the spring just popped off, put it back and see if that fixes it. If the spring is broken or missing, replace it. If the spring seems OK, look for debris jammed in the mechanism that the spring leads to. If there isn't anything obviously wrong you will need to take it to a mechanic unless you're prepared to do some deeper mechanical work. Good luck! Please rate my solution if helpful, thanks.
Aug 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Lawn mower idling up and down until it shuts off.
clean or replace your air cleaner that will fix it,I hope this helps you?
Oct 10, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
2009 Street Glide surged forward in the middle of an intersection
If you can lower the idle with the grip than it appears the return spring isn't working right or its missing. If you have an injector fueling when it is not supposed to be, that needs to be addressed before you ruin the rings and brgs. or get squished. I'm looking at it being a bad return spring. It should go to idle on it's own when you let go the grip.. Good Luck and ride safely. Ned
Aug 23, 2009 | 2008 Harley Davidson FLHX Street Glide
1997 chevy truck rpm slow to return to idle
check operation the throttle control motor or cable if used ( broken /missing return spring
Jul 13, 2017 | 1996 Chevrolet Blazer
When I start my jaguar, it idols at a fast speed but then as it warms up it will idol fast then slow, fast and slow and keep doing so
if it is a v12, and at idle when warm if it goes up and down then you need to rebalance the throttles, they are off balance causing the idle to raise and drop.
set the butteryflys behind the air cleaners to 2 thousands of an inch using a fella guage and make sure the linkage arms from the pedestal in the middle of the engine are set the same (one is not longer than the other)
JPTCAT
Jul 25, 2008 | 1986 Jaguar XJSC
Mtd Arnold Corp RearMounted Bagger for MTD and YardMan Riding Mowers For 20 Logo
71 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
