Question about google.com
Does it remove dark spot,without damaging the face
Doest it remove dark spot
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
No idea what you're talking about.
Posted on Sep 18, 2014
Why is there a discolored spot on crystal?
This could be caused by damage to one of the filtering films for the display. Did the crystal experience severe pressure or heat at some stage? I'd take it to a service center to have the crystal film checked or just live with it. Maybe the film will recover over time if not abused.
Sep 20, 2015 | Casio PAG80T 7V Triple Sensor Sea...
Sun damaged skin dark spots nwrinkles around mouth
Hi Hazel,
Please try Olay Regenerist Regenerating Lotion With Sunscreen Broad Spectrum Spf 15.
For the following skin types: Normal; Oily; Combination/Oily. It helps with these face concerns: Fine Lines/Wrinkles; Loss of
Firmness/Elasticity; Dull Skin; Uneven skin color/tone; Uneven texture; Dry/Flaky Skin; Sun Damage.
Thanks,
Shiju
Mar 31, 2013 | Freeman Vita K Solution Professional Age...
TOSHIBA 57LX177 SHADOW SPOT CENTER OF SCREEN
If my research is correct you recently replaced the lamp and then the "shadow spot center of screen" appeared.
Three possible reasons I can think of for this:
Something wrong with new lamp or on face of lamp--never touch the face of a lamp as oil from you hand can leave a residue and damage the lamp or cause a image issue.
Something inside on the optical lens or even the mirror causing this--not likely but possible.
A defect in the optical light engine in the set---usually if heat which comes from the lamp damages the engine it will be a color and not black---engine has a series of lens and baffles inside that heat can damage--causes minute separation inside of the lens etc.
If the old lamp works at all try putting it back to see if same issue--did you replace just the "bulb" in the housing or the whole cartridge?
If remove new lamp look at it and where it faces--usually a clear lens faces it and if some dirt on that..........
Jun 03, 2012 | Televison & Video
How to fix dark spot on screen?
If the dark spot is a soft-edged horizontal band all the way across the set, you have a fading Cold Cathode Fluorescent Lamp (CCFL tube). Look for flickering or a pink tint in this area when you turn on the set - if you see either of these symptoms that confirms the tube is worn out. (The dark band will coincide with a pair of pink and white or blue and white high voltage wires going to the edge of the panel assembly.) Replacement requires considerable soldering skill; you have to make a small wire connection to the leads on the ends of the tube, and you can't heat the connection for more than 3 seconds or you ruin the new tube.
If you have an irregular (roughly circular or elliptical) soft-edged dark blotch, you may have an unrepairable* problem with the LCD panel, or there is an irregularity in the reflector sheet in the back of the panel. You may be able to cheat by removing the back of the panel and placing a spacer behind the reflector sheet so you get a little more light through the dark spot - but this may cause shading of the surrounding area. Be careful not to detach the circuit board from the edge of the panel, and avoid touching the electronic circuitry - it's vulnerable to static electricity damage from your fingers.
If the dark spot has hard edges (the pixels right next to it are working normally) and is completely black, the problem may be in the electronics, or it could be broken pixels in the panel (those are not repairable). You would have to provide some detail on the shape so we can figure out where to look.
*Sometimes uneven lighting as a result of a panel fault can be remedied by gently massaging the face of the screen to redistribute the liquid crystal material, but the success rate is low. You can easily make things worse, but if you can't stand it the way it is, you haven't lost anything but some time.
Jul 06, 2011 | Protron PLTV-3750 Television
I have a small patch of red skin on my face. My doctor told me that it`s a cluster of blood vessels and that it most likely will not go away. I`ve tried covering it with make-up, but sometimes that makes...
Many of the smaller spots and skin lesions of the face are easily removed with lasers. These include small blood vessels on the face, small brown spots or age spots, and freckles and freckle-like spots on the face and elsewhere. To make the blood vessels less noticeable, concealer is your best choice. There are several brands out there, but the one I recommend is Colosé Cream Powder Concealer. It is great for minor skin imperfections and dark circles under the eyes.
Nov 23, 2010 | Health & Beauty
RU -44, small "pink" spot on screen.
Green is missing from the area where you see the pink (actually magenta) spot. This might be due to a large amount of dirt on the green lens. It may be due to damage to the face of the green picture tube. You need to remove the front screen so you can look into the lens and determine that.
Depending on the make and model of TV, the screen may be held on by snap fasteners and come loose when you pull on the plastic bezel surrounding it. Or the bezel may pull off to reveal brackets screwed into the cabinet that secure the screen. Or there may be a trim strip under the screen that pulls off to reveal screws. Remove those and the screen will swing up and off.
Once you can see the lenses, clean them with a soft rag and glass cleaner. With the set on, look down into the lens and you can see the face of the picture tube. If you see a dark spot on the face, the tube is damaged and would need to be replaced
Apr 22, 2009 | LG RU-44SZ61 44" Rear Projection...
How do I safely remove the crown of SEIKO ladies wristwatch
it might just lightly push on but not expert at this. clocks do. and some watches do. thats a fact.
Mar 26, 2009 | Seiko SNA413 Wrist Watch
google.com Logo
Top google.com Computers & Internet Experts
adam adms
adam adms
T-Comtech Repairs
T-Comtech Repairs
Are you a google.com Computer and Internet Expert? Answer questions, earn points and help others
