Question about Home Security
Utiliteck 150 w dust to dawn blinks off & on
Lifht comes on for a few minutes then goes off
2 Suggested Answers
  • 20 Answers
SOURCE: I have a 1997 pontiac sunfire and the anti theft
Pass Lock sensor is preventing the car from starting. You need to override it. I used a remote start module. Having this installed bypasses the pass lock sensor.
Posted on Aug 23, 2012
I have a sony projection tv the model number is KDFE42A10 Work's fine but the picture goes out and green light blink's About 49 times then picture comes back on after a few minutes it do the same thing...
It may be overheating check to see if the fan is running and the vents are not plugged with dust and or lint carefully clean out anything obstructing the vents and make sure fan is operating. Hope this helps.
Jan 01, 2014 | Televison & Video
Engine Light comes on and off. Blinks!
  • well you need TO CHECK IT AND GO TO AUTO ZONE ...
Nov 09, 2013 | 1994 GMC Yukon
Screen goes black when plugged in but still charges
dawn, it does not light up?
try removing battery for a few minutes as well as turn off power. Press the powerbutton for 60 seconds. Install battery again and power. Hopefully it may work.
Aug 02, 2013 | Lenovo Computers & Internet
5 yr old tv goes through cycle and tries to come on, eventually does but after many tries.
My sony did almost the exact same thing. I removed the bulb & cleaned all the dust out of the cooling ducts & the screen on the bulb was full of dust. That bought me about a month, then I replaced the bulb & haven't had a problem since(over a year ago). Just make sure you NEVER touch the glass of the new bulb with your hands,oil on your skin will greatly shorten the bulb life! I found a bulb at a local electronics store for under $200.00... don"t forget to clean dust from cooling ducts,& make sure cooling fan is working, bulb gets extremely hot!
Mar 02, 2012 | Televison & Video
Photo cell timer only stays on for a few minutes
Try it on another outlet, like in a dark bedroom without GFCI.
Buy another outdoor dawn-dusk timer.
Timers can be damaged by simple power outage, when power resumes there is a surge.
Timers stop working because the photo eye goes bad, or tiny 555 chip goes bad, etc.
Dec 20, 2011 | Hardware & Accessories
My sony big screne started shutting itself off and wouldnt come back on for several hours. Then it would power up and standby flash 7 times and after a few mins the picture would be gone but the sound...
On your tv you have cooling fans on the back side you will need to check to make sure that they are running. Lay your tv on the bed take off back cover (it's not hard) and used some air-in-the- can to remove dust from the back! If you need a fan go to Partstore.com (1-866-925-PART
Jan 26, 2011 | Sony Televison & Video
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
I have a 1997 pontiac sunfire and the anti theft light blinks as I try to start the car and the car will not start. I have to wait 20-30 minutes before the anti theft lifht goes out and then the car will...
Nov 25, 2009 | 1997 Pontiac Sunfire
Sony KDF-60XS 955 Video & audio goes out, comes back on
If the lamp fails to fire yes you will loose audio as well.
Aug 31, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Home Security Logo
82 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
