Question about Garden
Need to lft cab on6420 j.d.tractor leaking line
Have a line leak and need to lift the cab to get at it
  • Garden Master
  • 2,475 Answers
You should have a jack to jack the cab up.
Posted on May 08, 2014
2 Suggested Answers
BAMOUT
  • 2475 Answers
SOURCE: case tractor
Your lever is loose some place on lever.
Posted on May 31, 2013
1968 ford 2000 tractor 3 cylinders number 1 cylinder isn't getting fuel from injector pump the other 2 are is pump bad or not primed right
You need to ensure that here are no vacuum leaks in the line from the tank to the lift pump, the lift pump which looks very similar to a car petrol pump must be in good working order ie able to pump the minimum pressure and volume at cranking speed and idle speed.
If the lift pump is not working properly it will cause cavitation at the injector pump that will cause low pressure bubbles on the intake of the injector pump. If you have a good lift pump and there are no vacuum leaks between the tank and the lift pump then it may be down to bleeding the air out of the injector lines first at the pump, and then at the end of the injector lines (be very careful the diesel is at 170 to 175 times atmospheric pressure which is about 2500 pounds per square inch (which can penetrate skin deeply and even bone). Most of the Ford tractors use a rotary injection pump. Having only one cylinder not pressurizing is extremely unusual, try swapping the injectors between cylinders to see if it is a faulty injector, making sure to use new or at least anneal the old copper sealing washers and tension the injectors evenly with a tension wrench to correct torque. If the misfire then follows the injector it means your need the injectors servicing. New needles & nozzles for injectors is a lot cheaper than a new or rebuilt rotary injection pump. Please advise if it’s an inline pump. (which I doubt they were rare because they cost more).
Jun 01, 2016 | Ford Cars & Trucks
John deere 3800 tranmission oil leeking under cab somewhere
Hi Joe:
Nice looking tractor. I'm guessing you may have a leak in one of the hydraulic lines. There's usually access panels that you can remove so that you can see the lines and fittings. Sometimes a mirror on a handle and a flashlight will help you locate the problem. Once you find it, replacing the hose is usually easy and your local hydraulic shop will fabricate the needed part at a reasonable price.
SAFETY FIRST! Make sure that all hydraulics are lowered fully and that there is no residual pressure in the hydraulic tank. Open the filler cap to make sure.
Hope this helps.
Mar 05, 2015 | John Deere Garden
Need to lft tractor cab on 6420 ,line leaking
Some tractor have jacks to jack up the cab.
Mar 22, 2014 | Garden
Jondeerehow to lift cab
get a new line made at O'Riellys auto parts or NAPA
Smelling fuel fumes inside cab
Possible fuel line leaking or check around the area of the carb for leaks. Check all line connections Check gas tank all over. I doesn't need much of a leak to smell. Some times leaks develope at the tank top where the fuel pump is located as well.Please don't use a match for light to check this out
Mar 03, 2014 | 2000 GMC Sonoma Extended Cab
Kubota m59 hyd system not strong
Check your hydrolic fluid. If low, be sure there are no leaks. If your fluid is topped off and there are no leaks then your pump may be going bad.
Sep 16, 2013 | Cover My Tractor Tractor Cab-Enclosure for...
The hydraulic steel line on my 2010C bucket loader broke and I dumped a good amount of fluid before shutting everything off. Replaced line and filled tank up, everything worked fine for about 1/2 hour,...
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Sep 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Hydraulics get were they won't lift anything like round hay bales etc.
can be a lot of different problems-check fluid level if low fill to proper level --leak in hydro line-check all lines for leak--air in system -bleed system -wrong hydro fluid in system-check for correct fluid---seal at pump leaking-check around pump--controls leaking not holding allowing back pressure--test controls for internal leaks repair or replace if necessary--hydro pump internal malfunction/valves/piston/gears-pressure test repair or replace if necessary
Feb 01, 2010 | Diesel Allis Chalmers 190xt Tractor...
How to check/fill transmission fluid without a lft
look back by the flywall but before using any additive to seal a leak use a dye first to find out where the exact location of the leak is because sometime it looks like it is the seal but it is the backend of the valve cover gasket
Jan 12, 2009 | 2000 Chevrolet Corvette
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
