forum.ih8mud.com > Forums > Toyota Tech Forums > 80-Series Tech
Oct 1, 2010 - I'm looking for a "how to" on replacing the OEM power mast on a 97 LC. ... The only tricky part is removing the funky nut that holds the mast in. .... what to do with the radio mast on my newly acquired 1997 Lexus LX450. ... if I have a broken cable, but the antenna itself comes right out of the top with no cable.
www.cadillacforums.com > ... > Cadillac Tech Tips - How to fix it
May 9, 2009 - 15 posts - ‎12 authors
Remove the liner to access the antenna and disconnect ANY of the two ... If notlocked the motor receives continuously power and will drain ... Broken nylon wire lifting/lowering the antenna mast 4. ... The motor shaft comes out from the plastic casing after you take out ... Do not lubricate the cable or the mast.
If the cable broke in the antenna, you need to remove the antenna to remove the ... take a 17 mm wrench and remove the nut over the antenna where the mast comes out of the body. ... Hopefully the chrome sleeve will come with the old mast. ... Be careful not to drop them down too far. get the motor assembly on a bench ...Missing: tacoma ‎1997
? 20:53
https://www.youtube.com/watch?v=zcKwFto9_s0
May 24, 2013 - Uploaded by EricTheCarGuy
This video shows one way you can deal with a broken antenna. ... Find out why ... this video is that I did ...Missing: chrome
Hi, is the tv set to analogue broadcast, should it not be set to digital. I have a Grundig that does the same thing on analogue.If your tv is and/digi this might be the issue.
I suggest you go to the MENU setting and do a 'rescan' to see if you get the channels back. You might need to readjust your antenna, or make sure that the storm yesterday didn't damage your antenna, cable or power interruption on your TV box. Good luck.
the radio could be bad as well. if the tuner in the radio is bad it wont get reception either. go with a good aftermarket one not a cheapy there no good anyway.
In the USA broadcasts are not analog any longer they are digital. So if you have an antenna hooked up to your TV you will need a digital converter hooked up to your input wire (from antenna) and then an output from the converter to the TV. Most satellite and cable companies use RG56 cable which will work fine with an antenna set up as well, so cabling should not be a problem. Make sure you set your TV mode (input or source) to the proper input where you have hooked up the cable to the TV as well. It is unimportant which input you use, but the TV has to have it set to the same one. If you are outside of the USA, the above should be the same because broadcast over the air and antennas set ups are universally the same in nature and design. I hope this helps and good luck!
The problem is: The antenna(s) on the body of the radio are missing. Would like to know where they can be purchased. Not a rocket science question. Any assistance would be appreciated.
If the antenna connector is missing it probably has been broken off. I suggest that you use a HDTV cable box and connect with component connectors. Green, Blue, Red video + red & white audio.
If you are on off the air antenna, the cable box can be gotten from eBay.
If you have satellite, hook up either video or HDTV connections.
Hope this helps.
Lee
http://www.CrazyComputers.com
http://www.Todays-Info-Search.com
