Question about Arcam Solo Mini Compact stereo receiver with AM/FM/CD
A cd stuck in arcam mini solo will not eject. I have try to disconnect from power and it did not fix. The monitor goes from "initialising cd" to "bad cd" but there is no way to have the mini solo eject the cd.
Re bad disc message. the disc is stuck inside the unit. Initializes, cannot eject disc, then gives a 'bad disc' message.
Hi. I would contact Arcam directly for this - there may be a reset action you could perform or they could diagnose the fault further.
HTH
http://www.arcam.co.uk/advice/contact.htm
Jul 13, 2016 | Arcam Solo Mini Compact stereo receiver...
The unit displays a "bad disc' message after trying to initialize when turned on.The unit is loaded with a store bought disc in good condition.
It's probably some dirt or dust on the lens of the player. You can purchase stuff for cleaning the lens or a lens cleaning disc from your local hi-fi shop.
Jul 10, 2016 | Arcam Solo Mini Compact stereo receiver...
Arcam repair
Maybe a firmware (that's the running program) problem I'd contact Arcam, if your Solo has a USB input they should be able to send you a firmware update which you can download to a USB stick and then upload to the Solo (instructions will be in the manual). If not your local Arcam dealer should be able to do it for you Arcam warranties are 3 to 5 years. Don't now if they'll edit this but also try AV Forums online. good luck
Aug 19, 2014 | Arcam Audio Players & Recorders
CD player doesn't work
try another disc make sure it's a cd from a retailer. sometime home made disc don't play on older cd players because of formats. as for eject problems you might find you have to send it back to the retailer for repair
Apr 16, 2014 | Arcam Solo Music System Cd Amp Tuner...
Display on arcam say initialising... And nothing happens
It can be a faulty "cd drive unit" or "main board". In my case it was the main board.
Feb 06, 2014 | Arcam Solo Movie 2.1 Home Theater Receiver
Player will not eject cd
try to put your ear closer in cd tray, if its mechanical problem you will hear some clicking sounds which means the tray is trying to comes out. if it is the case, there is mini hole beside the eject button that is use for manual eject insert pin or needle in this hole and see if it will work, try this for start
Jan 29, 2014 | Pyle Pldnv78i 7-inch Double Din...
I have recently purchased a arcam alpha 10 amp to go with my arcam alpha 9 cd player and my monitor audio rs8 speakers. I am pleased with the amp and i am thinking of adding the power amp, the problem is i...
A better solution is like I have mine; use the Arcam 10 connected to the tweeters of your speakers & the power Amp connected to the woofers & link the pre out's on the 10 to the power Amp. using phono cables. The Manual can be downloaded from Arcams discontinued section of their website.
This Bi-Amp method gives a far superior sound than just using the 10 as a pre Amp.
May 04, 2009 | Audio Players & Recorders
Cd jammed in mini cooper cd player.
decided to take car to dealers for them to fix on warranty.
Mar 28, 2008 | Car Audio & Video
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Panasonic PV-GS150 wont eject
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 17, 2007 | Panasonic PV-GS150 Mini DV Digital...
Arcam Solo Mini Compact stereo receiver with AM/FM/CD Logo
199 people viewed this question
Top Arcam Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
berggei
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
