Question about BreatheAudio Solar Storm 16s110v Tanning Bed W/ Dual Twister Lamps
Fan will not turn off
What relay is most common to go beach hut 48160 to fan
I've got a mini one 2002 cooling fan dose not work unless I turn the a/c on if I don't turn the a/c on it will Overheat
7 Common Repair Problems Mini Cooper Owners Face
www.britishamericanauto.com/car.../7-Common-Repair-Problems-Mini-...
Feb 3, 2014 - This describes the top seven Mini Cooper repair problems owners may ... out the cooling fan and other related parts while the vehicle is apart. ... MiniCoopers aren't the most expensive cars to purchase new, and with .... Your article was a great read and at almost 60K miles , I've been through a few of them.
Mini Cooper cooling fan relay switch located Questions ...
www.fixya.com > ... > Cars & Trucks > Mini
Mini Cooper cars & trucks cooling fan relay switch located questions and answers. Ask your Mini cooling fan relay switch located related question. Get free help from topMini experts. ... I've also seen that problem in some Minis that required the fan motor to be replaced. ... The fan on my cooper s 2002 wont go on any idea.
Radiator Fan won't turn off! - North American Motoring
www.northamericanmotoring.com/...problems.../31220-radiator-fan-wo...
Sep 26, 2004 - Join Date: Aug 2002 ... I've posted a few times here on NAM that I never heard my car's electric fan run after the car was shut off. ... If it does not shut off then, replace that relay (you can find this relay at many ... Took the car in today to get thisproblem fixed. ... There is a recall on aux fan for MINI Cooper.
Dec 26, 2015 | Mini Cars & Trucks
Telephone number required for Beach Hut Silverdale NZ
Beach Hut at Silverdale, New Zealand Phone:+64 9-426 8913
Nov 23, 2013 | Video Game Consoles & Games
Is it ok to keep the stuff you find on the beach with a metal detector?
In general yes - finders keepers! But if you are on a private beach, national park or historic site, it's not necessarily yours to keep. In some places you need permission to use the metal detector and it's best to get that in writing and keep it on you while you are hunting.
Feb 21, 2013 | Retail Supplies
95 eagle vision 3.5l......cooling fans in-op.
There are actually two relays. You may be looking at the second one. The first one turn is turned on by the pcm based on temp sensor inputs. The other is the high speed relay turned on by the ac switch. Do the fans come on when you turn the ac on? I would pull out the low speed relay and probe the relay socket with a volt/ohmmeter. Make sure the pcm is sending a ground signal to the relay when the engine reaches operating temp.
Not sure about the failure rate of the parts, but a relay is easy to test.
Aug 01, 2017 | 1997 Eagle Vision
Cooling fan does not come on can't tell what tells ecm to signal the relay
You asked a specific question (answered that) but here is the entire thing....Coolant sensor sends signal to the computer, computer sends ground to relay and closes it to turn the fan on. There should also be a "bypass" that operates the fan when the ac clutch relay closes.
Jun 11, 2010 | 2002 Jeep Grand Cherokee
An came on by itself and won't cut off
If your indoor unit is electric and not gas or oil, then your problem is either in the control wiring or a relay. With your circuit breaker OFF: Start by removing the wire on "G" at your control board. If you have an older model, there might be a wire nut connection for your thermostat wires.......disconnect the wire nut with the green wire which is the most commonly colored wire used to control the fan. Tape off the end of the wire to prevent it from shorting......turn the breaker on. If the blower continues to run, you have a problem with a relay. If the unit is heating while the fan is running, you most likely have a stuck heating sequencer. If there is no heat, you most likely have a stuck fan relay.
Here is a video to help you identify heat relays/sequencers and fan relays. Having a stuck fan/blower relay is a fairly common problem. Often, you can gently tap the relay to "free" it and stop the fan. However, once they start "sticking", they will continue to do so.
I hope you find this information to be very helpful to you, moving forward. :-)
Apr 25, 2010 | Ruud UAKA060 Air Conditioner
2003 jeep grand cherokee radiator fan doesn't turn on
Disconnect the fan plug and hot wire it to the battery if the fan dosen't run, replace it. Otherwise, check the relay. The system operates by the temp sender sending a signal to the computer that activates the relay that turns the fan on. Fan should also come on with A/C.
Jun 28, 2009 | 2003 Jeep Grand Cherokee
Cold water fan won't shut off runs all the time.....
HI. this is a stuck fan relay switch that is located inside the unit. normally, if you unplug the unit for 5 minutes, this will reset the controls and, allow the relay switch to reset as well. i would try this before replacing the fan switch(relay).
Jun 18, 2009 | Hamilton Beach Water Cooler with Storage...
Hamilton beach water cooler is not cooling
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside the motor and several revolutions later might get some relief until a new motor is installed.
Jun 07, 2008 | Hamilton Beach Water Cooler with Storage...
No Cold Water
May 27, 2008 | Hamilton Beach Water Cooler with Storage...
BreatheAudio Solar Storm 16s110v Tanning Bed W/ Dual Twister Lamps Logo
22 people viewed this question
Top BreatheAudio Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a BreatheAudio Health and Beauty Expert? Answer questions, earn points and help others
