Question about GE Gfc530f Ge 12 Horsepower Disposall Garbage Disposer
Unclog ge disposall
Switch on, heard current through, but the disposer not working
Garbage disposal is clogged
Does the other side of the sink drain? Are you sure it's the disposal thats plugged? If the disposal is plugged you can turn it on and plunge it a few times and see if that makes a difference.
Jul 07, 2013 | Garbage Disposals
Garbage disposal and possible clogged drain
plug the one side of the sink so as to create a sealed enviroment for the plunger to work weffectively ... plung the open side ..
If this does not work , try running a metal coat hanger thru the outlet at the disposal exhaust line.
Mar 25, 2013 | Electrical Supplies
Garbarator will not turn
Copy following link for general troubleshoot resources, including reset button, unclogging and freeing the cutter disc.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Oct 16, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do you take it apart to unclog the disposal?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Sep 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Our dishwasher doesn't turn on--no power. I have
There is sometimes a switch mext to the disposall that switches the dishwasher on & off. if no luck revers the 2 plugs just to see if it will come on if not then check that the plug is hooked up under the front of the dishwasher behind the cover at the bottem.
Sep 12, 2009 | KitchenAid Dishwashers
Large amonts of water does not drain from tub and spills on to the floor. I have a lg. single drain sink with an ACE model 2000 1/2 hp disposal.
is the disposal working? if it isn't turning then find an alan wrench and turn it by hand there is a place to do that on the very bottom of the disposal in the center. the disposal should work after that and unclog the sink.
Aug 01, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Resetting Garbage Disposal
should have came with a alen key use it. to loosen the blades that are stuck on the bottom of the gaburator theree should be a hole in the middle. Just fine a alen key that fits in the hole and turn it around and then turn it on should solve your problem
Jun 05, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Soapy water standing in bottom not rinsing soap off dishes
It sounds as if it is not draining. Try to trace the drain line under the sink. Usually it goes into a disposall. The port where it connects to the disposall may be clogged. Another thought. If you had the disposall replaced recently they may not have taken the knock out plug out which would give the drain water no where to go.
Apr 09, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE disposall gfc 700 gets stuck
It sounds like the internal works are starting to corrode. You can remove the rubber shield and use a flashlight with the unit unplugged of coarse and look to see if something is caught under one of "teeth". If you don't see anything, then replace the unit.
Mar 21, 2009 | Little Giant SDS-10 Sewage Disposal System...
GE Gfc530f Ge 12 Horsepower Disposall Garbage Disposer Logo
42 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
