Question about Samsung RF267AERS French Door Refrigerator
After a power outgage could'n reset control panel. Far right 8 for refrig/power button is blinking
Far right 8 for fefrig/power button is blinking and I can't reset the control panel. The refrigerator is running
5 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Samsung RS2555SL Side by Side Refrigerator
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician.
Posted on May 19, 2008
SOURCE: power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Posted on Aug 15, 2009
taran_2005
  • 10515 Answers
SOURCE: Samsung refrigerator model #RS2533SW sserial#755843CTA02409
This is a common problem. The situation you mentioned is highly suggestive of faulty control board ( or call as motherboard ). You could try to unplug the refrigerator for few minutes, say 15 minutes and then turn it ON. If you do not see any improvement, it would confirm faulty control board and needs replacement.
However, there were few models in the past which had a reset option where you need to hold the power up and power freeze pads at the same time until their little lights come on then you press a small square button on the ice-maker then the compressor and fans start up.
Thanks and Regards
taran_2005
Posted on Apr 07, 2011
  • 489 Answers
SOURCE: After a power outage, the control panel on front
The control board went into self diagnosis when the power was applied. It found an error in one or more of the systems. You will need a qualified technician to come out and see what the problems is. To bypass this problem for now, press the "Super Freeze" button and the "Super Cool" button together for 6 seconds simultaneously. This operation will put the refrigerator back to normal operation till the power is interrupted again. Good luck.
Posted on Jun 19, 2011
Right 8 on refrig/power cool button is blinking and won't reset
Samsung 8888 Display Panel.
To reset, press, Energy Saver & Display Panel buttons, simultaneously, and hold for 10 seconds. A beep will occur. The refrigerator will run diagnostics from there. Replace all your favorite settings.
No worries the refrigerator defaults to preprogrammed cooling and freezing after the power comes back on. Your water dispenser and the rest of the extras are dependent on the command prompt display. I placed these directions in copy within the pages of my favorite cook book. Never to be without the solution again.
Mar 23, 2014 | Samsung RF267AERS French Door Refrigerator
I have no power to my kenmore elite dryer, model 110.87089601. I had a sudden power outgage and checked the circut brakers. Is there a reset button anywhere?
Unfortunately there is not a reset button or circuit breaker or even a fusible link in that model of dryer.
But before you panic, I would recommend that you trip and reset the dryer circuit breaker (unplug the dryer first) in your house circuit breaker panel to make sure it is really set. Then measure the volatage at the outlet for the dryer with a multimeter (remember it is 220V) to make sure you have both 110V legs at the outlet. If everything is good up to the outlet, you will need to open up your dryer cabinet to find out where you lose the voltage. When you get to a point that you have volatage on one side of a component but not on the other - that part is normally bad.
Jun 24, 2011 | Dryers
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Breaker that powers my sub-zero side by side keeps popping off
The refrige has a name plate what is the rated amps for the refrige and what size breaker u have for it. How far is the refrig from the breaker panel. If you give me more info i can help with this. I can only suggest now or guess 1.) Breaker is bad 2.) Compressor motor is starting to fail. With an A.C Ammeter right at the breaker panel go to the breaker that supplies power to your refrig and measure how much amps it is using and compare it to the name plate specifications
Jul 23, 2009 | Sub-Zero 685/S Stainless Steel Side by...
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Cooling did not resume after power outage
you need to do a reset on the control by pressing the two top buttons until it resets.
Mar 26, 2009 | Samsung SRS20DTD Side by Side Refrigerator
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Control panel for freezer and refrigerator
Behind the back panel of the freezer section is the evaperator assembly. on the rh side of the evaperator is a sensor pack that is for the defrost cycle. there is a thermo fuse inside of this pack that is open. The fridge goes into an error state if this fuse is open. unplugging the fridge resets the system. the sensor pack will have to be replaced.
Apr 23, 2007 | LG LRBN22514ST Bottom Freezer Refrigerator
Whirlpool Refrig Side by side
the problem is almost certainly in the controller or its power supply. Try pulling the plug for a minute or two - for some reason the display portion of the controller may have been sent out to lunch by a power surge or alpha particle. It woudn't be the first time. Check for bad connections between the display panel and the power supply and solder joints on the controller board. With everything else operational, a bad microcontroller chip is not that likely but is still a possibility. Good luck
May 18, 2006 | Whirlpool ED2FHSS Side by Side...
Samsung RF267AERS French Door Refrigerator Logo
66 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
